Drums
Discussion in 'The Garage' started by 84gmcjimmy, Dec 22, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    On a rear axle, with drum brakes...when it's not attached to a vehicle or wheels, are the drums supposed to fall off? I was moving a axle today and one of the drums fell off??
    thanks
    EDIT:
    I don't know much about brakes, sorry about the newbie question.
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Could happen if the drums aren't pressed on with the studs through them. Usually semi-float axles, I had a rear dana 60(ff) that the drums could come off with out removing the hub/axle.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The wheels and lug nuts are what holds the drums on , considering I assume you are talking a 5 or 6 lug GM semi floater :d
    Although some are supposed to have little shim clips that thread on and hold em , most don't make it back on after the first brake service :wink1:
  4. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    if the shoes arent squeezing the drum ( you pushing the brakes) then yeah they should in most cases come off...
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Ah I forgot to mention it was a 10 bolt haha
    Thanks for the help.
