DRW D60 to SRW D60... whats invloved?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Feb 27, 2004.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    what all is involved in converting a dually D60 to a single wheel D60? /forums/images/graemlins/dunno.gif
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Depends on which make 60 you have, but it should be as simple as finding a set of SRW hubs, and installing them. Just swapped my Ford 60 from SRW to DRW - and all it took was the DRW hubs. /forums/images/graemlins/thumb.gif
    -Dan
  3. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I just checked into the, you can either replace the hub or have WMS cut it down and slap some new lugstuds in. WMS machines them for $250 a set, also check here ( Dana 60 Bible ) it has a good write up at the bottome about converting them. /forums/images/graemlins/thumb.gif
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    any competent(splg) machine shop should be able to convert DRW hubs into SRW.
    u will need to have the wheel mounting surface machined off. remove the bolts holdingon the rotor, drill those holes out to hold a srw wheel stud. the wms - wms is 1" narrower that a regular SRW. if u are scared of the ears left on the DRW for the wheel mounting surface u can have a .5" spacer made. this would also give u the original SRW wms-wms measurement
  5. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I just finished doing this to mine.
    I bought these through Six States:
    The dually wheel bearing hubs, and rotors are different.
  6. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    the hubs are different, but DRW can be made into SRW.
    the rotors are the same part & share the same part #.
  7. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    NOT TRUE /forums/images/graemlins/rolleyes.gif
    rotors from a dually will not work unless modified.
    DRW rotors bolt to the hub with bolts. in order to make them work you must reem out the stud holes to 43/64".
  8. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    the ones from my SRW hubs bolted right up to the DRW hub. the local parts house had the same part #.
    what u are saying is the DRW rotor will not go on the SRW hub (w/out being modified)? i stand corrected. i did the swap the oppisite way & it worked fine.
  9. beater74
    May 29, 2001
    1,749
    atlanta
    yup the holes on a DRW rotor are threaded. /forums/images/graemlins/waytogo.gif
  10. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    drill the holes on DRW rotor to 11/16" and you are good to go...same as SRW rotor....the hole size is the only difference. /forums/images/graemlins/thumb.gif
  11. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Hijack on
    Beater74, your avatar is [darn] hilarious
    Hijack off
