DRW SRW C&C Rear widths?
Discussion in 'The Garage' started by DavidB, Mar 18, 2006.
  1. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    OK i've done some searching but haven't found anything concrete. Anyone know? What's the narrowest? How does one do DRW and keep both tires under a straight bed? THANX
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
  3. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    The BV Bible is good.
    For 73-87 trucks, though, it's a bit simpler.
    Wide DRW is almost invariably a D70.
    Narrow DRW is the C&C 14BFF.
    SRW is the regular 14BFF.
    The two 14BFF's differ only by the brake/hub combo, and the location of the flange that the brake backing plate mounts to. The axle shafts are the same length and the axle itself is the same width; the DRW hubs shift the WMS in 2".
    You can do DRW on a regular 14BFF by changing hubs *and* switching to weld-on discs, or moving the backing flange in.
    -- A
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    First off - you need to tub the inner fenders. (or lift so tires end up below box floor :crazy:)
    You can put DRW wheels on the SRW axle... tires stick out a little. Can be taken care of with small flares. Brakes need to be customized for wheel clearance, or run the 11" drum setup.
    C&C axle will put the tires right under the truck. Requires the 1-ton spring spacing though.... because there's only ~44" between the backing plates. :crazy:
  5. dremu
    Feb 27, 2000
    15,954
    445
    U2S is absolutely right on all counts, and I have committed a grave sin by not pic-whoring myself :haha:
    This is my tow rig, with a 1-ton 14BFF, using SRW hubs but dually brakes (which are currently being tossed for disc.)
    You do end up with < 48" between the wheel wells, so no plywood sheets flat in the bed; and with the SRW hubs, the tires stick out a bit -- these are 235/85-16's, stock size (no CybrFire stuff here! :D )
    You can see I tubbed the wheel wells in 3.5", I think, each side, and I have room to push the wheels/tires in with DRW hubs if I choose to in the future.
    -- A
  6. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Thanks guys that's what I was looking for. I'll prolly be flatbedding it, so no tubbing for me. Next I need to figger out how to get 11.00x16 Michelins on there :D
  7. sweetk30
    Nov 1, 2004
    25,537
    536
    when you do that let me know for my flatbed cab chassie truck built .:rolleyes: :D
  8. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Got my truck - prolly end up SRW. Check out Cousin Willard (ORD) when pics come available. willyswanter's is impressive.
  9. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    Same shafts, same housing - except for the location of the backing plate flanges.
