Dry Rot and Blow outs?
Discussion in 'The Garage' started by Sinful_Nature, Jun 14, 2003.
  1. Sinful_Nature
    Sinful_Nature Registered Member
    Jun 14, 2002
    90
    Raymond, NH
    As I was checking the pressure in my old beat up 38" TSL swampers I noticed that the dry rot is to a point that air is leaking out the sidewall (the square indented area the Swamper lettering is).
    Upon seeing this I thought blow out, but not sure. I have an hours ride to reach my club's weekend adventure spot, which within an area of no cell phone service (so I can't ask them about it).
    ANy feedback? Am I asking for a blow out with dry rot to the point that it is leaking out the side wall?
    Thanks!
    ~ Russ
    PS- At the moment I do not have a spare, I just upgraded to 3/4 axles and 38s.
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    a spare tire is good, unless your waist size is your spair tire /forums/images/graemlins/blush.gif, but get a spair, worth its weight if you get a flat or, get some tire sealint in a spary can, but get lots of it, for bigger tires /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  3. Sinful_Nature
    Jun 14, 2002
    90
    Raymond, NH
    Usually I do run with a spare, as I did when I had my 36s on there. A new spare is in the works, I was just wondering if Dry Rotted Swampers ever blow out (during highway travel). Can't imagine what it would be like doing 60 on the highway to have one those let go in a quick fashion. /forums/images/graemlins/smile.gif
    ~ Russ
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I had an 11 year old tire go out yesterday. The tread llet go like all the Firestones did. Good thing it wasn't a front tire.
    tomorrow I'm going with 4 new ones, and upgrading the spare.
    It's bad enough if something happens to you, but the other guy really doesn't deserve it. Although it doesn't happen anymore, we would like to think that everyone sharing the highways with us keeps their vehicle in a safe condition.
  5. Sinful_Nature
    Jun 14, 2002
    90
    Raymond, NH
    Good point, the reason my rig hasn't left the driveway since.
  6. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,612
    561
    Wasilla AK,
    Put some tubes In them I know it's kinda bootie fab but It works That's what I did with my 44" GROUNDHAWGS they were leaking out the side walls when I got them I put tubes in them and have been running them since with out troubles I don't take long trips or run very fast (but who does on 44" tires ) I have them back on the truck right Know (I have tsl's but I sold the rims they were on ) /forums/images/graemlins/truck.gif
  7. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i was going to say tubes also.i had them in 3 of my tires ( got pissed at people going slow around a semi-tire carcass so i drove over it and got 3 flats), the tubes were in those 40's far almost 3 yrs. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  8. Sinful_Nature
    Jun 14, 2002
    90
    Raymond, NH
    I was thinking of tubes, how much flex do you lose from using them? I do alot of rock crawling at low tire pressure (although with tubes I could run it even lower, right? )
  9. boggerless
    May 26, 2003
    22,728
    96
    you know i never thought about that back then, and i've never crawled with tubes, but how bad can it be. 1/2 apd or 3/4 a pd.whose that acurate ahyway?i do know that it saves you from buying a new tire,no radials. it will over heat in a radial.as long as the tire is not literally falling apart and you don't speed you should be strait. get new tires when you can. don't push it. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  10. boggerless
    May 26, 2003
    22,728
    96
    you are not kidding about lot's of them.that crap only runs in the center of the tread, and it used to be dangerous to tire changing people(it may still be) some times they would get a spark off the rim and it would blow up. no sh*t /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  11. Sinful_Nature
    Jun 14, 2002
    90
    Raymond, NH
    They do sell non-flamable "fix a flat" now.
    You maid a comment inregards to running a tube in a radial, which I have at the moment. Not a wise idea?
    Personally I am tried of used and old beat up tires. New tires with new rims are diffently in the near future. Just need to find the doe first. /forums/images/graemlins/smile.gif
