dry start?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by foxman, Nov 26, 2001.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    When My 90 K5 350 tbi is cold, When it starts, it makes a grinding type noise for a couple of seconds. It seems to go away but at an idle it softly phases in and out for a couple of seconds at a time. It is sparatic and has no pattern. My oil presure reads just under 30 PSI in the dash. Anybody feild this one.
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I'm not too sure on what the clicking noises are... might be a starter not fully disengaging? But I do know that if dry starting is the problem, you could try changing your oil and putting in 4 quarts of your usual oil and 1 quart of Lucas Oil Stabilizer. This stuff is nice and thick, helps eliminate dry starts, and helps out compression. I've used it in both of the vehicles I've owned, and I know our city DPS uses it in all of their trucks and heavy equipment too.
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    How cold are we talking here ?
    If its not getting oil to the right places durning start-up, you might look into a Pre-Oiler, there $$$$
    but can make an engine last forever !
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Check your power steering fluid. If its low it can cause a sound like that. Just a thought.
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Check your tranny fluid too. Could be the torque convertor clutches making the noise as the fluid hasn't warmed up yet.
