Dry Sump Oil Systems
Discussion in 'The Garage' started by blazer_87, Oct 26, 2005.
  1. blazer_87
    blazer_87 Registered Member
    Oct 1, 2001
    72
    Section, Alabama
    What are you thoughts on a dry sump oil system? There can be one of two benefits of doing this and I would like to get everyone elses opinion.
    1. You can run with an oil pan that is much more shallow oil pan to prevent rocks from knocking the bottom of your pan off. Also you can put pickups in all 4 corners of the pan so that when you are on steep angles your oil pick up will always have oil.
    2. The second option is that you can lower your entire engine with the shallow pan by about 4". This could help lower your cg.
    I have just been thinking of some mods to do to mine and wanted to hear your thoughts.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    which would also lower your trans and t-case. prob not a good thing for a flat underside (which is what most of us want).
    and it probably costs way more than i want to think about.
    ryan
  3. blazer_87
    Oct 1, 2001
    72
    Section, Alabama
    ok, maybe the 2nd option is not so good after all. I have yet to think of anything negative about the first one, except maybe a bit pricey.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    one of my friends did this on his late model bacause he kept putting holes in his pan around the track. he showed my the reciepts once, he has more into his drysump that i do into my entire truck. :eek1:
  5. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    a few more reasons to do it:
    more crankcase vacumn; will make you rings seal better, less blow-by
    better oil control; no starving the pick-up
    less oil slosh on the crank; less power needed to turn it
    ease of cooling and filtration
    more water tight
    and some not to:
    cost
    Leaks in the plumbing
    Rebuilding the pump every so often
    most oil tanks are vented, so no floping the beast
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The bummer is that a complete dry sump setup costs a couple of THOUSAND dollars. :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1:
    Here's a link to some pumps.
