Dual 241's, strong enough?
Discussion in 'The Garage' started by wayne, Aug 11, 2006.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I'm tossing around the idea of doing dual 241 t cases. Using a driver side front section for the front and tie it to my passenger side 241 rear. I think 5.44 low would work out ok but the problem is will the rear t case hold up? I am pretty sure the only problem might be the chain. Has anybody even tried this? Is it realistic to think it will hold up fairly well? My reasons for even thinking about this is because I can do it pretty cheap and it will be some serious low range.
  2. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I'm having a hard time picturing what you are saying. I guess its to early or something. Are you talking about doing a doubler-type set up with two NP241 transfer cases?
  3. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yes he is, there are kits to remove the chain from a 241 and run another case behind it. Personally I'd consider something stronger for the second case if you were to even consider it. Maybe a Dana 300? Then you have the option to build it up and use a 4:1 kit down the road for EVEN more low range?
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    IIRC they put the 241 behind some desiels... oughta be plenty strong enough.
    j
  6. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have a round pattern 205 sitting in the garage. I just want to mess around with stuff I already have set up.
  7. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    That is an awesome idea! Never heard of that before. This place rocks.
  8. JanneB
    JanneB Registered Member Premium Member
    Dec 9, 2004
    62
    5
    Finland
    It would be 7.3984, right?
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Not sure how you came up with that number. The t case's have 2.72 low so double is 5.44.
  10. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    I believe you multiply the two numbers, not double them.
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yes, you multiply the numbers... so its ~7.4:1.
    j
  12. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Hence the term torque MULTIPLICATION:D
    Ira
  13. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    :doah: What was I thinking. I totally forgot to multiply instead of add. Anyhow 7.4-1 would be super low. I seriously think I'm going to do this and see what happens.
  14. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Yes I have 1 in my dodge cummins/ats/241 But I think the 241 in that has beefier parts than 241 in the blazer.
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    it is a NP241HD, has a bigger chain for one.
  16. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I run double stacked 208's in my "Marvzda"....
    The 208's are holding up fine.... But I think they are because I'm pumping 1.6 liter 4 cyl power thru them and the rig weighs 2k lbs...
    With a fullsize truck and even mild V8 power, I would bet on the 2nd 208 checking out early....
    Using the front half of it for a range box and a 205 downstream sounds like a much better deal... :waytogo:
    BTW.... I'm making an assumption that the strength of a 208 and 241 are pretty much in the same ballpark...
    Marv
  17. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    as far as I know the critical dimensions of the 208 and 241 are similar. Dunno about the 241 HD though, I forgot about them being different in the dodges. :thinking: Wonder if they are beefier, other than the chain...
    j
  18. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Well I guess since nobody seems to have actually tired this I might give it a shot and see what happens. I believe the weak link will be the chain so I will pack a spare.
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    oh I didn't realize you don't know. There is a guy on Pirate who sells kits to do it... He mainly uses 231s for the reduction box but I am pretty certain he uses 241s as well. Look in the Vendor's Section.
    And I must say Wayne, its not so much the chain breaking, but if it lets loose, the case is a goner. A spare case would be a better thought if you are really worried.
  20. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
