Dual 3" with headers
Discussion in 'The Garage' started by dammit32, Jul 1, 2003.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    Dual 3\" with headers
    I am thinking of doing headers and retaining my 3" pipes on the drivers side...will it have enough back pressure if I add the 3" pipes on the passenger side to create duals?.
  2. gruveb
    gruveb Registered Member
    Jun 26, 2003
    51
    Rio Rico, Arizona
    Re: Dual 3\" with headers
    You planning on building that thing to run in the 10 second bracket? If not, then that exhaust is way to big! 2 1/2" duals is actually a little large.
    Most street/strip cars that can run in 12's or better run 2 1/2" duals around here.
    I've got 2" duals on there right now (without a balancer tube), and when I rebuild it, I'm gonna stick with 2".
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Everyone will tell you 3in is to big
    BUT if you have a pretty healty SB its fine but if your headers wont accept a 3in pipe go a few feet of 2.5 then step it up to 3 Big exuasy wont sound as raspy though more hollow
  4. gruveb
    Jun 26, 2003
    51
    Rio Rico, Arizona
    A 3" exhaust with 2 1/2" pipes somewhere along the line isn't any better than just a 2 1/2" all the way around, but it will sound louder, same way a megaphone works. But the 2 1/2" section will act as a bottle neck. The closer to the engine the bottle neck is, the greater effect it will have also.
    Consider the headers. If you're running headers that are 1 1/2" at the primaries, a 3" exhaust is likely a large waste of money.
    Nothing runs worse than an engine with mismatched parts, I've learned that the hard way!
  5. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    if it's a stock or half way modified SBC it's gonna get lost with 3" duals, sh!it 2 1/2 is to big. i'd go no bigger than 2 1/4" duals.
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    If your header wont take anything bigger then 2½ then you only have about 2ft of that then 3in it will flow better
  7. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    The problem with dual 3" is that you lose all of your exaust velocity. Given a set amount of fumes exiting the engine, a smaller pipe will have more velocity. Velocity is important for cylender scavenging and low end torque. Scavenging is when the exaust traveling through the tube actually creates a vaccuum on the cylender to pull exaust out and suck fuel and air in. I have found that for a chevy 350, dual 2 1/4" pipes are ideal for an engine that is operated below 5500 RPM. /forums/images/graemlins/thumb.gif
