Dual batteries on 85?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Jun 13, 2001.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I am looking to install dual batteries on my 85. I was planning on buying a setup designed for an RV from JC Whitney or something like that. Found one that supports two batteries and up to a 90 amp alternator for $50. Does this sound good? Any other ideas?
    85 GMC Jimmy, 305 w/TH700-NP208, 32X11.5 BFG ATs, 15x10 Eagles, Smittybuilt tube nerf bars and bumbers
  2. dyeager535
    26,975
    Dual batteries are cool IF you need it. Extra wiring in the charging system, (heck ANY electrical system) if it can be avoided, should be. I am going to eventually set mine up so that I can hook up two batteries when I need to (like when I've been using my electric trolling motor) but so that I don't need two in there all the time.
    Diesels had two battery setups, so that is a good source for some of the wiring and the other battery tray, which is a bolt in with some light drilling.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  3. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    I'm running dual Optima batteries in my '85 Jimmy - if you're quick you can see it on my web site on the Truck Mods page before Steve kills the site tonight :-( . I've gone with WranglerNW hardware: driver's side battery tray, relay and harness. I'm happy with the quality, instructions for install were clear, and no problems. Suppose you could get the driver's side tray from a diesel truck.
    was fun while it lasted, <A target="_blank" HREF=http://desertrider.coloradok5.com>http://desertrider.coloradok5.com</A>
  4. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    I'm planning to do the same - LMC Truck has the drivers side battery tray - Factory new
    www.lmctruck.com
    This site only allows you to order a catalog - you can also call 800-222-5664
    The cost for a drivers side battery tray is $29.95 - it will save you the time of searching junk yards!
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I just completed my install with the NW Power kit. Very clean.
    Also GREAT wiring kit with fuses, battery lugs and toggle switch. I purchased the battery tray direct from the dealer - let me know if you need part # (I know I have it here somewhere...)
    I am running a high CCA AC delco as primary and a deep cycle yellow top optima as secondary.
    NW Power - (800)962-2616
    Good products, directions and customer support is value-add to me and NW has both.
    Dave
    "Visualize Whirled Peas"
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Check out these articles from ORC:
    http://www.off-road.com/chevy/reviews/wranglerdb/
    Murphy's Laws on Life :
    "The longer you wait in line, the greater the liklihood that you are standing in the wrong line." [​IMG]
  7. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    Thanks for the info. I tend to run the battery down while camping. First I need a bigger alternator, but after that is the dual kit. If nothing else for the peace of mind. I think the Hellroaring kit is the way I will go.
