dual batteries or tripple?
Discussion in 'The Garage' started by RootBreaker, Aug 8, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    Ok so I was at autozone the other day.... they had a battery isolator on clearance..
    from $39.99 to $19.99
    I know not great but hey... so I bought it...
    now I could hook up my batteries in parallel like I was going to or use this isolator... now it is only a 90amp but i only have a 63amp alt...so I am fine there..
    however with this winch (patriot 15k)... should I run 2 batteries for the winch and 1 on the other side of the isolator for the truck?????
    whatcha think?
    just looking into it... or just ditch the isolator and run parallel 2 batteries?
  2. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    2 batteries will take a big load off the alt when winching. Try it with the isolater. If you have low voltage problems with it, you can always replace it with a continous duty solenoid. Three would probally be a pain in the a#@.
    Click here for more info and options on the subject.Multi Batteries
