dual batteries- where to get the 2nd tray?
Discussion in 'The Garage' started by mike reeh, May 30, 2005.
  1. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    gonna put a 2nd battery in my truck and was wondering where to find a battery tray? GM would be preferred.. they dont happen to be interchangeable do they? thanks......
    mike
  2. diesel4me
    Jul 24, 2003
    17,576
    943
    Massachussetts
    Stock diesel GM trucks....
    Any GM truck with a diesel had dual batteries...you can get new trays from a GM dealer,or used junkyard ones...not sure if they are the same--there might be a "right" and "left"...should bolt right in !.. :crazy:
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    I managed to get one from an 81 + into my 80. I was only able to use three mounting points, but it worked and looked good. Just put two bolts into the fender, using a wrench through the marker light, and a ratchet in the engine bay. I then drilled a new hole in the core support, and put a bolt down there. If you used a spacer, you could also use the bolt hole that would fit on an 81 + on the fender well. Biggest challenge was making a battery cable long enough to get all the way over to the battery.
    I had to relocate my battery to make things work nice with the TPI -- My old battery tray is now my air filter housing mount :D
  4. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    left side and right side only. on 81-up.
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  6. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    My 82 k5 came with dual trays, but i did notice that lmc truck sells both if you can't find one
  7. mike reeh
    Jul 23, 2001
    752
    San Diego, CA
    thanks! i forgot how rad this place was........
    mike
