Dual Batteries?? Yes or no?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5XLR8R, Sep 21, 2000.
  1. K5XLR8R
    K5XLR8R 1/2 ton status
    Aug 22, 2000
    210
    Washington State
    The concept of dual batteries? when to go to two batteries; off road lights,stereo amp, and cb..is this to much for my battery??...... advantages? dis-advantages?? ease of hook up?? etc..opinions wanted
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Very good ?
    The good ol boy answer is, if you run true duals and true dual possi front and rear, you should run true dual batteries. And don't for get to run true dual alternators for that true dual charging. CHARGE !
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    How much horse power do you lose when you run two alternators? Have you actualy run this type of set-up? I am asking 'cause I feel sorta dumb buying a Super HD alt. for a on-board welder
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    First ask your self what you would want the second battery for? I wanted a second battery for backup and extra power when winching! Dual batts are an awsome insurance policy whe out in the backwoods!! You do not need dual altinators if you have a Hellraoring Isolator/Combiner. This unit knows when to send charge to eather batterie and keeps them both at the same charge level. When in a winching sanario and your main batt. is slowing down you can combine the two batts for more power. AND, if you play your radio all night long at the campsite and your main batt. is all drained out you just flip the switch and vaarrrooommm the motor cranks and starts!!!!
    Go for IT!!!
    late
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  5. Executioner
    Feb 22, 2000
    1,530
    1 HP = 746 Watts
    12V *(times) current draw is watts. Example 150 Watt K.C. off road lights. 12V*12.5Amps=150Watts
    So if the altnator is say suppling 13V at 100 Amps, that suppling 1300 Watts to say the weilder.
    When you say loss what do you mean? If the altnator is suppling about 1300watts, the engine must supply about
    1.5 HP to turn the alternator, so if this is the loss your asking about you can easily afford 1-5 HP for an extra
    alternator.
    Good luck
  6. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    executioner.... what are you smoking, dude?
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
  7. Executioner
    Feb 22, 2000
    1,530
    A pack of ture dual Salem's, ok
  8. fr8train
    Aug 2, 2000
    1,712
    Maryland
    So I basically lose what the K&N filter is giving me, not bad. Do you have to have to make custom brackets or are they available in a Performance store?
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  10. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    Why not get a dual output alt.? The premire power welding co. makes them with a HD external regulator and you can charge both bats. at the same time, hook them together if you drain one down after winching or if you left your stereo on all night, have a marine switch so you can hook bat. reserve together for above situations and switch back to charge each bat.separately
