Dual battery isolator installed, now problems
Discussion in 'The Garage' started by hidesertwheelin, Feb 6, 2007.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    I installed a dual battery isolator in My suburban. Nothing works until I turn the key "on". No dome lights when the doors open, radio won't save pre-sets. Anyway to fix this, the radio part is especially awnoing.
  2. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Yes, check your wiring, when you put in the isolator you've mistakenly wired the Hot curcuit in with the Ignition Switch curcuit.
    Explain a little more about your "Dual Battery Isolator." Are you isolating one battery from the other, Two batteries from one, or two batteries from two batteries?
