dual battery set-up
Discussion in 'The Garage' started by Hannibal, May 30, 2005.
  1. Hannibal
    Hannibal Registered Member
    May 30, 2005
    34
    BC Canada
    I run a 140amp alternator and have 2 batteries hooked up through a solonoid. It just don't seem to charge right. Any ideas on best way to run dual batteries?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Many people will just hook them together parallel (pos to pos, neg to neg). Below is a diagram I made of how I will hook mine up. I will have one main battery and a bank of three batteries as the "secondary" battery. When the ignition is turned on the batteries will be connected and both will start the vehicle and both will charge. When you turn the key off the batteries will disconnect from each other and the secondary battery will be isolated from the vehicle so it won't/can't discharge. I can use the secondary battery to jump start the primary if I have to. You will need to use a "hot through start" ignition source to the solenoid, and the manual switch is for jump starting yourself.
  3. 78blazaer
    78blazaer Registered Member
    Aug 15, 2002
    36
    Hmm, I just installed a dual battery on my K5 using Painless battery separator.
    I like a lot. It saved me once. What I like about this kit is that it allows me to choose whether to use two batteries ( primary and secondary) or just one battery (primary). The circuitry is designed so that when the vehicle is running, it automatically charges both batteries, and when its not running, it automatically disconnects the secondary battery. This way if you have draw somewhere from your electrical accessories, it won't drain both of your battery. The secondary battery is isolated. However there is a manual override switch where you can toggle between single to dual battery operation. The idea is, winch all you can on the primary battery, and if you completely drain your primary battery, you can always switch to the secondary. Never winch on both batteries unless you really have to and if the load requires more amps to get you out of the rut. Enjoy.
    If you have a minute, check out my winch and dual battery project.
    http://community.webshots.com/photo/246000292/292913072PTEGMS
    http://community.webshots.com/photo/246000292/292913121UKGxlY
    http://community.webshots.com/photo/246000292/292913158GlwysN
    http://community.webshots.com/photo/246000292/292913198rktQBb
    http://community.webshots.com/photo/246000292/292913247fxVXgD
    http://community.webshots.com/photo/246000292/292913293ZaLvIX
    http://community.webshots.com/photo/246000292/292913330oUSXXA
  4. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    How about a marine dual battery switch? It lets you manually pic one, or both batteries and you can turn them both "off" if you park for a while.
  5. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    A 140A alt is more then enough to keep 2 batteries charged. Sounds like you have a charging circuit problem, or an excessive drain somewhere.
  6. Hannibal
    May 30, 2005
    34
    BC Canada
    I agree, I'm gonna hook-up a volt or ammeter to see if draws from an accessory somewhere, and of-course clean every dang connection.
  7. louied
    louied Registered Member
    Mar 19, 2002
    84
    Philadelphia
    my experience is you need to use the same batteries on both sides, because the charging rates are different.
  8. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
  9. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I've got a Hellroaring setup just waiting to go in... :waytogo:
  10. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
  11. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    what he said... wouldn't that work? personally, I don't want all kinds of whizbang capabilities and nifty bling bling features I'll never use, off/1/2/1+2 is plenty of adjustability for me. Anyone use a marine switch like that?
    I was thinking of something like this...
    it has a 350 amp continuous rating... or if thats over kill, they have a cool keyed one that can handle 250a cont...
    j
  12. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    I also have a 140 amp alt and I run 3 optima yellow tops. I used a battery isolator which keeps all three batterys seperate. I run one for start up and stock acc., one for exterior power ( like lights, air horns, anything add on under the hood or a winch), and one for my stereo system so I can run it dead and not worry about starting the rig. Plus it allows me to jump start myself by connecting the posts on the isolator. Just another option. I think I paid around $130 for the isolator from JC Whitney. and like mentioned earlier, you should run the same type of battery so they don't discharge each other or over charge.
  13. garlicbreath
    May 17, 2003
    1,136
    Denver
    If you keep all 3 seperate, how do you charge them?
  14. louied
    Mar 19, 2002
    84
    Philadelphia
    sweet set up!! what is the relay u are using? How do u like the set up?
  15. keith
    1,158
    La Fayette, GA
    I got the Painless Wiring 250 amp kit. Still got to mount the switch. I plan to upgrade the battery cables with heavier gauge and shorten them too. those are all 2 gauge and should work fine though
  16. louied
    Mar 19, 2002
    84
    Philadelphia
    it looks like u have a starter solenoid at the bottom of the innner fender?
    how much was the kit?
  17. louied
    Mar 19, 2002
    84
    Philadelphia
    i have a pac-200 relay on the firewall.
  18. seschev3
    Jan 19, 2005
    308
    clayton, ca
    It is an isolator which is basically huge diodes. So the batterries are seperated but all charge from the alternator. There are no relays necessary.
    I used to run the solonoids like some of you others are running when I ran 2 batts. But with 3 I needed to go with an isolator set up.
  19. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I use the set up from wranglerNW. It's a great system and has a neat in cab toggle switch for different functions. www.wranglernw.com
  20. keith
    1,158
    La Fayette, GA
    Yes a did move the starter solenoid up from the starter to the inner fender.
