Dual battery setup
Discussion in 'The Garage' started by fordeater, Mar 23, 2004.
  1. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    I want to install a second battery in my rig cause i run KC lights and a stereo system etc.... what is the best way to run the batteries? I don't even know how i should wire them up. Any help would be greatly appreciated. I already got the drivers side battery tray, and i'm gonna run dual optimas. /forums/images/graemlins/thinking.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I plan on doing the same thing, i will be using a battery isolator and running all aftermarket stuff (lights,stereo, whatever else) to that second battery and keep the primary factory battery used soley for the starting purposes.
    I have been told that the dealer sells a passenger side battery tray for like $25 or so for the dual setup, going to check in to it myself.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i plan on using a marine switch for the batteries. the place near me want $25 for the switch. the hook up is very simple, run both positive cables to the switch and 1 cable to the starter /forums/images/graemlins/waytogo.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have a $5 quick disconnect. I simply disconnect my 2nd battery when I'm going to let my truck sit more than overnight. No issues with leaving it overnight and hitting the key in the morning.
    Other setups rely on switches, solenoids, or relays. I am not lazy, I just open my hood and hook it up.
  6. 4xcrazy
    Oct 31, 2003
    9,471
    5
    You hit it on the head there bubba, /forums/images/graemlins/waytogo.gif Ya see, I AM lazy, /forums/images/graemlins/waytogo.gif i like the convenience of the automatic operation of the isolator charging the battery that needs it, and using each battery for its intended purpose, without having to pop the hood. /forums/images/graemlins/thumb.gif
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Tj , when you renew use the name 4xlazy /forums/images/graemlins/thumb.gif
  8. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  10. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I am using a daul battery switch control in the cab on the dash like this. It is the big red and black thing on the dash:
    [​IMG] Makes it quite conveinent to switch up as necessary.
    Bill
  11. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The search feature is your friend...
    I have a pushbutton that activates the Furd starter solenoid shown in my diagram above. It is located in the ashtray.
