Dual CB Antennas
Discussion in 'Communication (CB | GPS | HAM)' started by nad, Mar 3, 2006.
  1. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Does placing dual cophased CB antennas closer than ten feet apart really weaken the signal? Someone was recently telling me this, since I have dual antennas on my mirrors. Anyone know for sure?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    From what I've been told, yes.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes it does weaken them
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Personally, I run a single high quality antenna.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Ditto, i have a single firestick on my burb.
  6. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    I just think one CB antenna kinda looks out of place. Duals look a lot better, but if it weakens the signal, I guess one is always better. Thanks guys.
  7. bcrewcaptain
    bcrewcaptain Registered Member
    May 15, 2004
    60
    Charlottesville, Virginia
    short answer ...yes, unless you get them the proper distance apart(just over 8ft)
    go with one, its not worth the hassle of 2, it can be done with the right tuning but its a PAIN!
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've seen alot of people mount 2 antennas, but only run coax to 1 of then. Looks have never been a big issue for me, but if you want a second antenna as a dummy, go for it.
  9. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I run two 48 inch Barjan whips on my truck. Only one is hooked up. I was told that hooking up both screws up the output signals. I like the look of dual whips and i can afford the 18 bucks for a dummy.
    Here a pic of what they look like, i think just one wouldnt look that good.
  10. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    Even having the dummy antenna on the truck will "influence" your transmit and receive patterns.
    What this means is the dummy antenna will change the direction your system will transmit and receive best to/from.
    Most likely you will not see too much difference with the dummy on the rig though.
    How far are you trying to transmit?
    The best place for your antenna would be right in the middle of the roof.
    This gives me trouble as most of my offroading is in the woods.
    My solution is to mount my CB antenna on the bumper of my Blazer. This doesn't really bother me to much as the CB is only used on the trail anyway.
    I have ham radio to use if help is needed.
  11. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Its rare I ever try to transmit to someone that isnt in sight. IF they arent insight, they are never more then 3/4 or 1 mile away. I never had any problems.
