Dual CV Rear Drive Shaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BorregoK5, Dec 5, 2001.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I parked next to a K5 this morning which was equipped with a dual CV driveshaft (CV on both ends of the shaft). I managed to catch the guy and ask him a bit about it. They were 1330 CV's and added as a final vibration killing measure. Apperently he had a nasty time with his 8" suspension lift getting the vibes to go away once he geared the rear end, even with a CV at one end. The second CV killed it permanently. He's had it for about 6 months now and beat on it a few weekends worth but said he hasn't been overly abusive on it enough to form anything but a good opinion as far as streangth. He did say it doesn't vibrate at all at any speed, anymore. I hadn't seen this anywhere before so I thought I post it and see what kind of response comes back.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  2. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    With dual cv's whers the slip yoke and where did you get the cv to bolt to your rear end yoke?
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  3. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    He had a slip yolk conversion on the tcase. The rear end pinion was unchanged with 2nd ujoint ubolted to the yolk to finish the CV. I think if I were ever to run something like this, I would only do it to a high pinion rear end.
  4. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    we have a couple of shafts like that in our driveline junk pile ...i was playing around out there today , still messing with mine ...
    Kick It In The Firewall !!
    O R D's axles
    NO BREAKAGE
