dual electric fans thermosatat not opening?
Discussion in 'The Garage' started by wraenking, Oct 19, 2006.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    ok, from the post the other day if you read it, my fans were not coming on when the temp reached 185. i have checked the wiring a million times, and just bought another themrostat just in case.
    im checking the themrostat up to 220 degrees with a test light, and its is just not opening. fans work every other way fine.
    i have the thermostat into the neck on the manifold, and i know its getting plenty of flow
    any ideas??
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    what kind to T-stat do you have?
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    painless , 185 on, off at 170
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I've gotton a couple of bum t-stats from the store, brand new in box,no worky.
    I test any new t-stat's now on the stovetop in a pot of boiling water and a thermometer (meat thermo works well!). Make sure your wife isn't around.
  5. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    are you sure your motors t-stat is working ok? how old is the t-stat for your fans?
  6. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    Just to clarify for everyone, it's not a thermostat, it's the thermal switch triggering the fans...
    You could stove test that too... boil the **** out of it, pull it out with tongs and check continuity between the body and send stud..
  7. dyeager535
    26,979
    I should go look at the diagram, but I'm lazy.
    Are you checking the switch correctly? Assuming single prong switch, (normally open, closes at 185*) you are using one end of the test light on the switch, with the other end to a good 12V source?
    As an aside, if you have to buy yet another switch, your t-stat I'm assuming is 160* if you are using a switch that goes off at 170*?
  8. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    yeah, i can test the one thats not in the motor right now tomorrow. ill try the continuity test.
    thermostat in the truck is new.
  9. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    yes, ryoken actually told me about that. i have good ground on the body of the thermo switch, but nothing from the top connector when it hits 185.
    this is driving me nuts
    as far as thge wiring for the fans goes, no matter what when i hook the test light up to the 12 volt, i should get the light of the thermo switch triggered at 185
  10. dyeager535
    26,979
    Yeah you've got it right, the switch is used to ground your test light circuit, so if that's not happening at 185*, somethings wrong with the switch. (of course, assuming your test light works when you ground the correct lead)
    Not surprising given parts anymore that a new part doesn't work right. Which is why I don't have a problem re-using old parts like GM senders, etc. :)
  11. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    1st switch was brand new, and just bought a second yesterday. ill have to try boiling it tomorrow.
    what a pain nin the ass.
  12. dyeager535
    26,979
    Never know, maybe they were mismarked during manufacture. Some GM switches were 240*, so it's possible. Not likely, but then again, how likely is it that two brand new ones don't work right? (apparently, very!)
  13. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    i think ill just drive to pauls (ryoken) house with a sledge hammer and take it out on his k5 so not to damage my own lol
    thanks a lot for the hepl gain paul. and ill let you know soon on that plasma cutter.
  14. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    haha... :haha:
    Well, at least we got the switch aspect and the wiring straightened out... Let me know on the test. You could always stop by the marina at 3:30 too with the truck...
    And yeah, don't forget to ask those guys about the plasma.. That may save me 2 noisy days with a cutoff wheel... :doah:
    As far as the sledgehammer goes.........
    My truck.....
    Farts in your general direction! :p: :eek1: :bow: :haha:
  15. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    lmao, you fool. maybe i will stop by tomorrwo. staying in brick over the wweekend to watch a house anyways, so ill be close
    ill give you a buzz
