Dual Exhaust for 87 k5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by porkchop, May 8, 2002.
  1. porkchop
    porkchop Registered Member
    Apr 29, 2002
    21
    NH,seacoast
    I want to change out my stock exhaust for a duals
    I want to go with dayno max from the stock exhaust manifolds back
    what do I do with the oxgen sending unit ?
    any help on this would be great.
  2. dyeager535
    26,975
    Leave it as is (sensor location that is). I doubt you'll run into any problems, since the exhuast that is shared from one cylinder bank to the other is negligible. The O2 sensor on the truck is "before" the y-pipe joins, right?
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you have smog Nazi's that are anal about the law, then they could bust you for true duals. They are illegal for your truck. The are illegal on mine, but the Nazi's have never bothered me yet. If you are just going to replace from the exhaust manifolds back you could just do a highflow 3" exhaust system. It is legal, and it yields about the same results as duals unless you plan on having a big high reving motor.
  4. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    On my 87 truck the O2 sensor was in the driver's side manifold, so you shouldn't have to do anything to it.
