Dual exhaust on 97 6.5 TD?? can it be done??
Discussion in '1982-Present GM Diesel' started by yeild2me, Jul 6, 2003.
  1. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Man, I want duals on my truck. What I was thinking is dual pipes all the way back and turn out behind each rear tire.
    Can this be done?? Will it affect the turbo's operation??
    Thanks....Rob
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Well considering the turbo only has one outlet, then it would be impossible for it to be true duals. You would be better off with a single 3.5 or 4" pipe with a free flowing muffler. If you really want the look of duals, then get a Y pipe with dual tail pipes coming out each side of the truck. IMHO, duals on a turbodiesel look and sound pretty bad.
  3. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    I was looking under it today and saw a big round thing just after the manifolds. WTF is that?? My muffler was removed last summer, so it has a deep rumble. Can this round thing be removed too??
  4. BlueBlazer
    Feb 15, 2001
    1,940
    Catalytic converter would be my guess, but I dont know if 6.5s came with those. If you dont have emissions testing there, Id say get rid of it.
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    As already mentioned, you would have to "Y" the pipes off someplace behind the turbo. There might be a minimum distance away from the turbo you need to be before doing this also.
  6. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    well my 6.5 has dual exhaust... i want to upgrade to bigger pipes... dont know how its all set up but i have dual, right behind the rear tires /forums/images/graemlins/tongue.gif
  7. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Does your 6.5 have a turbo???
  8. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    its not a turbo.. sorry.. did i get u all worked up??? hmmmm...? /forums/images/graemlins/thinking.gif
  9. edeslaur1
    edeslaur1 1/2 ton status
    Jun 23, 2003
    193
    Oregon City, OR, 97045
    A single well-designed 3" flows better than dual 2.25s (And most 2.5s)
    So, you still want duals, eh?
    Options if you have a turbo
    1. Add a y-pipe after the turbo, come under the trans (front) and cross over, both pipes to mufflers to out the back
    2. One pipe into a muffler that does 1 into 2 (Flowmaster, etc.) Y out of the back of the muffler to wherever you want to go.
    Me? I'd run 3" all the way back. If I had the $$, it'd be Banks. My MH may be getting that since it's included in the turbo kit (if I can find one, anyways).
    It'll be going from duals to single 3"
    As it is, Gibson has always done me right and sounds good on those long hiway trips.
  10. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    When talking about dual exhaust it makes a huge difference whether or not you have a turbo. On a non-turbo you can just run true duals, with a turbo it's a whole different story.
  11. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    well im curious, what makes it so different and harder to run duals on a turbo?? /forums/images/graemlins/thinking.gif
  12. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    Because your left exhaust manifold is piped into your right exhaust manifold, then into your turbo and exits the turbo through a single down pipe that connects to your exhaust pipe. The only whay to run true dual exhaust and have a turbo is to run dual turbochargers. /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
  13. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i remember reading in one of the 4wheel mags that a 3" pipe has more volume than two 2" pipes. it was on their project diesel blazer. they removed the stock duels and went with a single 3". i dont think it was turbo tho. i personally like the look of a big single exhaust on a truck, but thats just me.
  14. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Yes, a single 3" pipe flows better than dual 2" pipes.
    The surface area for a pipe is pi*R^2 (3.14 x radius squared).
    Here are the numbers.
    3" pipe = 3.14 x 1.5^2 = 7.065 square inches
    2" pipe = 3.14 x 1^2 = 3.14 square inches
    dual 2" pipes = 3.14 + 3.14 = 6.28 square inches
  15. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    Reply you can do it with out the y pipe and true dual you will just have to bend your own headers to do it check out thirdgen.org go to the power adder msg board and they can tell you how its done belive me my Ta has a ATI turbo on it and it has a dual exaust. Alot of guys on this bord have used the diesel turbos on thier cars so they can tell you what to do.
    Earl
