Dual Exhaust- Transfer case clearance?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, Jan 24, 2001.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    The factory exhaust on my 84 has developed a nasty leak on the crossover pipe, and instead of repairing the rotted pipe, I want to run duals. I was under the truck for a few minutes yesterday and realized that there isn't much room on the passenger side due to the transfer case(208). Are there any reasons that this would cause a problem?
    And does anybody know anyhing about Dynomax Super Turbo mufflers? The local exhaust guy says that they're a good compromise between performance and sound deadening, and they only cost around $80 CDN apiece. Flowmasters are over double that amount......comments?
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Dual exhaust will work. Can't help with the mufflers.
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've got 2 1/2" duals on my 85, and the passenger side has about 1 1/2" of clearance on the TCase side, with almost 3" on the framerail side of the pipe. As far as your muffler concern goes, Summit Racing sells their own version of a Flowmaster, which sounds just alike, and appears to be the same quality construction for about 40.00 US (60 Canadian). You also may consider checking with other performance mailorder places to find a good price on the Flowmasters.
    Best of Luck to you
  4. Storm Trooper
    Nov 24, 2000
    4,640
    I'm having a dual exshaut system put on my 87 K5 right now. The guy is putting a 2-1/2" dual inlet/outlet stainless steel muffler on it and he says I should never need to change it again (about $150). I'll find out the name etc. It looks and should sound sweet plus it makes a clean job. I'll let you know. Post your question again in a couple days.
    [​IMG]<font color=red> Ride'in High In My K5! [​IMG]
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I run 2 1/4" duals and I have no problems with clearance.
    Murphy's Law :
    "When you don't know what your doing, do it neatly."
  6. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    I had dual 3 inch! with the 5 speed, 203 range box 205 t-case 45 gal fuel tank it was very very full. Pluss with a red line of 4500 even my 530 hp 400 does not need tow 3inch pipes and mufflers. Now the 87 to 92 y-pipe is two 21/2 to one 3 inch pipe its very clean and flows the cfm needed! And goes down the drivers side! A little mathe here the dual 2/12 inch has a area of 15.7 one 3 inch has an area of 9.5 this would mean that the 3 inch should handel a 350 or 400 ci motor in to the 5000 rpm range the dual 2.5 inch would go in to the 7000 rpm range. The 3 inch singel would move the tork band down. dual 2.5 would move it up the band. So though the duals sound cool. A free flowing singe 3 inch with a good y-pipe will flow more than needed plus move the tork band down were its needed! the singel 3 inch would be cheaper! Plus at the end of the day your ears wont rang as much.
    I understand the jeep thing I drive a BLAZER!!
    Ken
  7. 83k5project
    83k5project Newbie
    Dec 20, 2000
    4
    Illinios
    I have a set of the Dynomax Turbo's on my '83 K5 and on my '84 Cutlass. They have a great deap tone and very little back pressure, really let the motor breath.
    83 Blazer
    65 Olds 442
    65 Olds Cutlass
