Dual Exhaust
Discussion in 'The Garage' started by adamforsythe, Oct 31, 2004.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    What duel exhaust system can I use on a 1985 K5 Blazer?
    I can't find a duel exhaust system for my truck.
    Thank
    Adam
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i have no experience with off the shelf kits, i would recomend finding a local shop that bends pipe. ask around at the parts stores, they usaully can direct you to a decent place.
  3. mahorney
    mahorney Registered Member
    Jun 10, 2004
    28
    Highlands Ranch, CO
    My '86 Jimmy w/350 had flowmaster dual exhaust setup with headers (not sure what brand). Unfortunately, I was having trouble passing emissions and ripped it out to install a setup that would accomadate the A.I.R.
    So I paid premium for a set of Edelbrock headers. Big mistake. They are specially built to replace original single exhuast and be emissions legal. I didn't notice any difference in power, but the fit is aweful! The cross tube hangs down under the front drive shaft even with the skid plate under the transfer case, very exposed. And it was supposed to bolt right in, but I had to do some cutting.
    The Edelbrocks were expensive and poor fitting. I'll be either taking it in and having it custom rerouted or ripping it out and replacing it. I know that there was another header brand with A.I.R tubes for about half the price. Forget brand. I expect these are typical headers on the output side, but not certain. If so they might hook up to flowmaster. Or maybe flowmaster has an emissions legal setup. Not sure about that.
    So solution depends on emission requirements. But my fix was overkill for Denver bc they barely do a visual and I don't think the A.I.R. was a critical factor in getting my emissions down. A new cat and very lean jetting seemed to be the critical fixes. I probably could have got away with two new cats on my original setup!
    Mark
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello
    Thanks for the info
  5. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    If you live in a part of the United States that has annual emission inspections, then good luck finding a muffler shop that will put a complete dual exhaust system on a vehicle, which came with single exhaust as original equipment. Most will turn you down flat.
    What you can do is get them to set up a custom single exhaust system that can be easily modified at a later date, at home, because what you do at home is your own problem. This will cost you some money though...probably about $400.
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I live in a county where there are annual emissions inspections (actually after next yr, no more woohoo), anyway, took it to local meineke (or is it midas) anyway, take it first thing it the morning, and pay em cash, they have no probs with doin it. Just so long as they dont have a record of it, they dont care, least around here.
  7. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    I wish I could find a shop that would do that.
  8. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    small shop out of the way...there all over and will do anything. Its not their problem if you won't pass smog.
  9. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    You can trailer it there and tell them it is an "off road only" vehicle. /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  10. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    LMC truck has dual exhaust kits
  11. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    You can find bolt on systems that seperate after the cat, but all I have seen run on the same side cause of the gas tank on the other side. Check out JEGS or Summit Racing, I've seen the kits in their catalogs
  12. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    I have been to three different exhaust shops that said they would not put a dual system on a vehicle that came with a single system originally because they could be heavily fined by the State B.A.R. for doing it.
    With a 4X4 truck I would run the whole dual exhaust down the left side only (one pipe over the cross-member, and the other under the cross-member) because the transfer case interferes on the right side, and then just turn them down in front of the differential. I would probably use the "tube" style Cherry Bomb mufflers, in order to fit two mufflers side-by-side, or regular performance mufflers turned horizontally side-by-side.
    What about the issue of a CO2 sensor? Is there such thing as a dual CO2 system?
  13. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Im running a true dual 2.5, even ran it on my sbc, it has no probs clearing the t-case on the passenger side, I think I could stuff a 3.5" pipe in there, and it would just be close. Im running at the moment dual cats and dual flow 50's.
    As far as the oxygen sensor, when i had my sbc it was in the drivers side header, now its in the drivers side collector(no bung was in my coated BB headers). I had to install a heated o2, but other than that, no problems.
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Hello,
    Thank
    Adam
    [/ QUOTE ] Before you go to a duel exhaust, do you have emission testing ?? If not, kewl, go for it. You'll need too get a local exhaust shop too bend some pipes for you.
  15. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Well when I put the duel exhaust on I will put a cat and muffler on each side. So I think I will pass the emission test
    Adam
