dual exhaust
Discussion in 'The Garage' started by BeaterBurb90, Aug 29, 2006.
  1. BeaterBurb90
    BeaterBurb90 Newbie
    Aug 6, 2006
    4
    Red Lion, Pa
    does anyone know where to get a good dual exhaust kit, preferably direct fit. i have an '87 blazer with flowtech headers and i am having trouble getting something to fit.
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Just let the local Meineke bend one up... Our local guy rocks... cheap too...
  3. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    Well for stock duals I would go with LMC they are for a long bed but easy to trim. If you have the header flange to regular just use them $169.95 and no worries about any missing parts ;)
    http://www.lmctruck.com/icatalog/bzc/0093.html
    Been on my truck almost a year and still great I drive it almost every day.
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    X2 on LMC exhaust
  5. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I had looked at the LMC exhaust for my '90 K5. It doesn't say it will fit a '90 but seems like it should. Am I correct in assuming it will? Also, I'm in the process of putting in a MPFI 468. Would this exhaust work w/ a BBC?
  6. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    When most of the "local" shops bend the pipes don't they have a crimp in them that reduces the size of the pipe unless they are mandrel bent? Can Meineke do this?
  7. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    They should fit.... Go to an auto parts store and look at the exhaust pipe book for a 1973 - 1978 Blazer with a big block and compare the pipes in the pictures. In most cases where the body hasn't changed I believe you can use earlier pipes on vehicles.
    I say this based on the fact that I put dual system on a 1980 Camaro Z28 using 1974 pipes just had to modify the doughnut flange and shorten the pipes before muffler. The basic V design of motors should be the same and exhaust manifolds haven't changed that much. Check the exhaust manifold styles to compare.
  8. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    I called around and none of the meineke / midas / etc shops did mandrels much less the 3" pipe i want. I found a guy around the corner from my house who's going to do mine but he's a independant shop not tied to a big chain.
    I looked at the LMC pipes too but they're too small. Like 2.25 i think. Maybe 2.5.
  9. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Yea I'm being told I need 3" pipe for the BBC. You would think that in all of these off-road magazines there would be a place that sells complete exhaust kits for out trucks. Anyone, know of one? I definitely want to buy a mandrel bent kit. No need in going w/ 3" pipes if they are going to be shrunk down to 2" in the bends.
  10. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Ya the LMC exhaust wouldn't compliment a healthy big block.
    I think Flow Master makes at least cat back systems for our trucks :dunno:
  11. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Flowmaster is very proud of their products too. $$$$$$$$$$$$$$$$$$ I want to run two pipes w/ two mufflers from the engine back. I definitely don't want to have to pay for two flowmasters.
  12. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    I think Summit Racing has a couple full kits with mandrel bends. I think they are 2.5" though. I had a local shop do mine recently.
  13. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    I got your Jeep thing and now it burns when I pee!
    At the risk of being an old fart. I feel that if the BB needed bigger pipes then back in the 70's they would of come from the factory that way. The 1979 C20 I had with a 454 in it only had 2.5" pipes. Unless you have so radically changed your motor most engines need some back presure.
    Before you start pulling out flow test remember I said "most", not all engines. If you want the bang just run headers and straight pipes :rolleyes: or while your at it go with stainless steel pipes for it. All I am saying is it is your truck you decide what you want and do it. The key here was a good dual exhaust kit, preferably direct fit.
  14. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    2.5" may be fine, if I can get a kit w/ a good fit then that works for me. I don't want LOUD I just want a good low rumble.
  15. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    when I swap in the 572 I'm building I'll be running some drag style headers w/ 4" collectors into 3" pipe into a pair of spintech XL mufflers into 3.5" pipe after that.
  16. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    I don't have digital video recorder or I would go out and record what mine sounds like. As best as I can describe the LMC system it has a lower level sound as far a db than stock Harley for the throaty level. I get looks when I get into mine with a hard foot.
    I have paid more for exhaust and not been as happy. I priced the parts from Murray's Auto parts and was shocked! If you want a good sound that won't get you a ticket or draw attention to you then yes go with LMCs. By the way I have had a Harley *loud pipes save lives*, true race cars 1/4 mile use only and street toys with headers and all the jazz of the 70's *including Nitrous Oxide and I love my exhaust on my Blazer.
  17. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Well.... I'm spoiled.... Our local Meineke guy is amazing.... 10 time bender of the year awards and all that... and yes, he does mandrel bends... Very, very reasonable prices too...
    I just sent a kid from work over there for exhaust on his Dakota.... He loved it, and the price.... Bought me lunch for turning him on to the place...
  18. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I have a complete setup from Dynomax on my truck. it's 2.5" and mandrel bent. the kit only comes with pipe you need to buy the mufflers seperate. was about $150 couple years back.
