Dual flows over...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by anatomiczero, Aug 21, 2001.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    My Jimmy sounds pretty good right now, it had dual glass packs (blue streaks i think) and it also has the stock, rusted exhaust manifolds. I want to put headers on it, will headers alone make it sound louder.better? I'm also thinking of replacing the glass packs with the flowmaster 40 series 2 chamber. Would those make it sound better? Also how much hp should i get from headers, will i beable to feel the difference?
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    The headers will make it louder with the glasspacks, but will also provide a better sound. Headers and Flows sound killer - I've noticed increased throttle response, and a little better seat of the pants with my system - Hedman hedders and 40 series flows on 2.5" pipe.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. anatomiczero
    Jun 26, 2001
    418
    Washington
    Cool, I think I'll go with the headers first than maybe 40's if i want it even louder. Right now it goes into 1 cat, then splits, should i have 2 cats so it's straight through?
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Definitely go with two cats and true duals if the smog police find it acceptable in your area. A single cat is just a huge bottleneck - I don't have cats on mine at all.
    BTW - You need to fill out your profile so we can provide a little more detailed info[​IMG]
    Dos mas Tecates!!!
  5. anatomiczero
    Jun 26, 2001
    418
    Washington
    OK, filled out my profile. So how much should this cost me? Do I just replace the maifolds and will it bolt right up to my exhaust, or do I have to put some new pipe in? thanks for the help
    Oh yea, 1 more thing, should I use an H pipe or just have it come out straight?
    Black 1980 GMC Jimmy
    350-TH350-NP205
    Dual glasspacks<P ID="edit"><FONT class="small">Edited by anatomiczero on 08/21/01 07:02 PM.</FONT></P>
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Depends if you get block hugger's or full length tri-y's as to if you have to modify the pipes. IMO full length ones are better. The flows will be quieter than the glasspacks but will have more deep tones and the flows will be better at highway speed(ie quieter than the glasspacks at speed)
    ~~'84 K5~~
    Check it out at:
    <a target="_blank" href=http://www.k5.rockcrawler.com>www.k5.rockcrawler.com</a>
  7. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    To run a true dual system you'll need new pipe - My system cost just over $300 with headers, mufflers, pipe, and installation. The "H" pipe will help out a little in the low-end, I'd go ahead and do it while you're at it.
    Dos mas Tecates!!!
  8. anatomiczero
    Jun 26, 2001
    418
    Washington
    OK, thanks for the help. So I'm thinking of getting:
    headers
    another cat
    H pipe from the cats
    new 2.5" pipe (if i need it)
    flowmaster 40's (wondering about these, just want to make sure it sounds awesome)
    then take the headers and flowmasters to a shop and have em install it. I have no prob doing it myself, but I would have to drive with open headers and I'm not sure if i would hmm, open headers will sound awesome lol, hmmm but I'm not sure how i'll do the pipes, so I'll prob take it to a shop. Now I have to find a good place, I'm doubting Midas so I'll have to look around.
    350-TH350-NP205
    Dual glasspacks
  9. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    I run hooker super comp headers with true dual 40 series flowmaster exuast and its true daul no cats to mufflers right from the headers ......sounds awsome but its not good when its time to smog.....haha
  10. anatomiczero
    Jun 26, 2001
    418
    Washington
    Hmm, no cats, i guess i want to pass emissions so i'll keep em. Does it have a deep tone, set off car alarms?
    350-TH350-NP205
    Dual glasspacks
  11. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I took mine to the muffler shop with open headers - Sounded killer, but I also had every cop in town following me[​IMG], so I never got to have too much fun with it.
    Dos mas Tecates!!!
  12. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    When I put my headers and flows on the Jimmy I cut the old pipe off at about the transfer case crossmember and bolted my headers on and used some of that cheap flex pipe to run to my old rusted 2" pipe so I could get to the muffler shop. It sounded pretty redneck going to the muffler shop which was 17 or so miles away. Plus I only had one clean spot on the rig a 12" spot on the windshield to see( Never let friends talk you into mudding when you have a muffler appointment) I bought the 2 camber flowmaster with 2.5" pipe and 3" tips. With a stock 350 this sounded bad @$$, just what I was wanting to hear. I'm going for the same set up on the Willy's but I'll purchase the tail pipe kit from jegs or summit that is made for the truck and route my own. Nothing sounds better then 2 chamber flows.... just my .02
    <font color=red>It's not what you drive, but what drives you</font color=red>( Or is it what you work on,lol)
    <font color=orange> 1955 willy's on a 1977 blazer chassis </font color=orange>
  13. Chaz316
    Chaz316 1/2 ton status
    Jul 25, 2001
    224
    Georgia
    Im thinking about adding the headers to my 73. It currently has a leak at the manifold so I figured I'd put on the headers when I changed the gaskets(Makes too much sense). I live pretty close to a muffler shop but I am not sure if they are not open on saturday.
    I'd have tp get it done all in the same day.
    "If it aint broke don't fix it" is like a 4 letter word.
    <a target="_blank" href=http://www.phatboy.alloffroad.com>PhatBoy.AllOffRoad.com </a>
  14. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Has anyone heard the difference in sound between a set of duals with an "H" crossover pipe versus an "X" crossover pipe?
    I remeber reading somewhere that the "X"-style crossover was actually a little more powerful (though probably harder to build) and had a 'unique' sound. I've never heard one, so I don't know if thats BAD or GOOD.
    Just curious
    -Greg72
  15. tRustyK5
    Jul 23, 2000
    36,180
    1,387
    E-town baby!
    I took my flows and drove to my local Midas with open headers...they did an awsome job! I also have full length headers and true duals with 2 chamber flows and 2 1/2" pipe. It sounds very nice...if you want even louder add some 3" or 3 1/2" boom tubes at the tips.[​IMG]
    Rene
  16. LittlePig
    LittlePig 1/2 ton status
    Aug 9, 2000
    299
    East Texas
    Anyone running single-chanber flows? Too loud? I had a very small center inlet-center outlet flowmaster on my last truck (3" in and out) that sounded killer with the megaphone it had, but it was single exhaust.
    Email: littlepig@keepandbeararms.com
    ICQ: 84108805
  17. 77Blazer
    77Blazer 1/2 ton status
    Aug 13, 2001
    197
    Long beach CA
    I run dual 2 chamber flowmasters and Hedman torque step heddars and man its loud!!!
    350, sm465, NP205, 14 Bolt w/Detroit locker(465 ratio), Dana 60 465, 38.5 swampers
  18. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Hey 77blazer What kind of power increase did you get ?
    1977 K5 Blazer [​IMG]
  19. 77Blazer
    Aug 13, 2001
    197
    Long beach CA
    a giant one! i had just a single exhaust with a cat then i switched to the tork step heddars ditched the cat and went duals! but now i want to add on the X pipe.
  20. anatomiczero
    Jun 26, 2001
    418
    Washington
    I'm gonna get headers, an H pipe, another cat, then maybe flows. Wouldn't the glasspaks have more power since theyre straight through instaed of going through chambers? I'll have to see what the glasspacks sound paired with headers.
    350-TH350-NP205
    Dual glasspacks
