Dual front shocks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Jun 26, 2000.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    My 89 has dual shocks up front and singles in the rear. I've noticed that several late model K5's are like this. Anybody know the reasoning for this? I know mine has the towing package but I would have figured it would give duals all around if that was the case.
    89 K5 Silverado
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I dunno why...my '90 sub came with the factory duals...I think it was optional. Best advice...remove one of the front shocks on each side, it'll ride MUCH better, and unless you're running Baja at 40+ MPH, you won't need the dual shocks. Besides, it breaks off the lower mounts over time!!
    ken
  3. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
    <font color=purple>The lower mounts do break. But if you remove a shock makes sure the remaining one is valved correctly. What I mean is that the original intention of this setup was to have two shocks valved lighter to run duals. What happens is we buy aftermarket's (Rancho 5000's) that are supposed to be for our application, but they are valved for single applications, & therefore ride rougher.</font color=purple>
    <font color=purple>Rick
    86 K-5</font color=purple>
    http://www.BigBadBowTie.ColoradoK5.com
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I appreciate the input and I'll keep it in mind, but for now I'm gonna stick with the one, I take it all the late models came with it though..??
    89 K5 Silverado
  5. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    My 90 did not come with them
    [​IMG]Go prepared
    </font color=red>90 k5 soon to be big, bad, and mean
  6. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    I didn't have dual shock setup stock, but i did put a triple shock setup on my 90 Blazer. i have to say i love it. I rode around for a while with just one shock to see the difference and i like it with 3 shocks. It kept the bouncing to a minimum on the interstate when i go over overpasses. Here is a pic...
    http://k5junkie.coloradok5.com/
  7. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    i would like to put dual fronts on my 82. is it possible?
    Bigger is Better
    Cameron Burnett
    82 Jimmy
  8. 82Jimmy
    Jun 9, 2000
    702
    Those triples are cool! I would like to know how to do that...and is it possible on my 82?
    Bigger is Better
    Cameron Burnett
    82 Jimmy
  9. K5Junkie
    Mar 29, 2000
    499
    Gulfport, MS
  10. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Those of ya'll with out the dual shocks, do ya'll have the towing package?
    89 K5 Silverado
  11. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Beleive the heavy duty front suspension is a seperate option this also has 3 leaf front springs besides the dual front shocks. My 87 has the dual shocks but not the towing package. The 89 I had did not have dual shocks but did have the tow package.
  12. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Hmmmm.....
    So I guess it looks like I have a heavy duty front end (with a puny 10 bolt [​IMG]).
    89 K5 Silverado
  13. James90
    May 18, 2000
    986
    Rocky Mount NC
    are the hoops hard to put on
    [​IMG]Go prepared
  14. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Doesn't the Rancho triple mount hook to your steering knuckle? With my Dana 60 front axle, and the crossover, I wasn't sure if it would work.
    Shawn
    87 K5
  15. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I have the dual shocks and my rig has the towing package
    YEEEEE HAWWWWW[​IMG]
  16. K5Junkie
    Mar 29, 2000
    499
    Gulfport, MS
    As for the difficulty of the installion of the hoops...I had to modify the pass. side hoop so it would clear the AC box. And on the drivers side lower mount i had to modify it to clear the 4" raised steering arm. Beside that it was not too bad to install them.
    Shawn, as for your question yes the lower brackets attach to the steering knuckles. I don't think it would get in the way of the crossover steering. At least i hope not b/c i am planning on putting crossover by the end of the summer.
