Dual fuel tanks
Discussion in '1982-Present GM Diesel' started by 4x4_76, Mar 23, 2002.
  1. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    My brother is going to install dual fuel tanks on his 6.2 C-10.He is going to get tank sometime next week and he needs to know that can he use the tank switch from gasser.The tank and the switch are from gasser.He was told that diesel has different switch,that it has more hose connections.I have never seen one,but I figured that it needs six connections.
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    If his switch and valve have six ports, then he should be fine.
    Some gassers used a three port valve......he cannot use this one. He must have six ports to handle the return lines.
    Casey
  3. 4x4_76
    Jul 22, 2001
    628
    Ylämaa, Finland
    OK!
    Thanks/forums/images/icons/smile.gif
