dual Fuel tanks
Discussion in 'The Garage' started by Tshane, Aug 1, 2003.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    My truck is set up for dual tanks but the guy that had it before me unhook both tanks when he painted the truck and only hooked up one... i find this a waste to have that extra tank sitting down there and not being used and that be nice having 2 tanks with a hungary v8...the problem is my haynes manuel doesnt have a good diagram of how the fuel lines are suppose to run from the valve and the tanks... i was wondering if anyone out there had a good diagram sence it looks like a maze of different lines down there... hopefully someone can help me out /forums/images/graemlins/truck.gif
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    if you drop the tank you want to hook up the lines are probobly sitting right there..now what lines hook up to which line on the sender i done know..and i need to find out the same thing cause im in the middle of putting a new 20 gallon tank in my truck in place of the leaking twin 16's.
  3. Tshane
    Nov 26, 2002
    144
    Peoria, Illinois
    yea well the other guy unhooked everything so i'm really lost
  4. Tshane
    Nov 26, 2002
    144
    Peoria, Illinois
    come on someone out there has to have some info on this. HELP! lol /forums/images/graemlins/1zhelp.gif
  5. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Depends on the year of the truck. The older ones just have one line from the sender of each tank that goes into a solenoid valve that is hooked to the hard line that runs up to the fuel pump. If the valve is missing you need to get one.
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    thats how mines setup i think..mines an 86
  7. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Even if it is 79(I think) or newer all you need are the two 3/8" lines you can plug the rest they were just for emission equipment.
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea ones for the carbon cansiter i think..which isnt even hooked up on my truck so who cares..
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    dont some use a return line?
    isnt his TBI which would have a return line?
    even so it is pretty simple to figure
    1 line from each tank(2 total) to selector valve for fuel to engine
    1 line from each tank(2 total) to selector valve for return of fuel or vapor
    then 1 line from selector to engine compartment for fuel to engine
    and 1 line from selector to engine compartment for return of fuel or vapor
    the fuel to engine lines will usually be larger then the return/vapor lines
    usually there is a single wire to trigger the solenoid and the unit grounds through the mount
    if that isnt correct spit out a description and someone will figure it out in short order
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    mj, you've got the tbi plumbing right, don't know about his truck.
    The 6 port selector valves are a bit more expensive than the 3 port valves. You absolutely can not run the return to only one tank. Major fire hazard there.
