Dual Gas tank Wireing?
Discussion in 'The Garage' started by Esteban86K5, Apr 28, 2005.
  1. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    On the wiring harness there are 4 wires, blue, green, brown, and a brown w/ a white strip where do they go?
    Asking for a friend. :D
    THANKS!!!
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Read the instructions! :deal: :doah:
    :haha: :D
  3. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    Here's some info i copied out of a couple posts i saw last year.
    _______________________________________________________________
  4. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    Someone did a lot of research!
    Wow!--what a lot of info that post has!--I pulled my hair out on my 82 K20 diesel with dual tanks,and I had the wiring diagram!(A diesel is slightly different,they have another wire to both sending units for the "water in fuel" light--but similar otherwise,different color wires too)..I found out someone chopped out the fuel selector valve,its switch,and a bunch of hoses!--also noticed the drivers side tank leaks,so I just use the other tank--lucky I was able to get the gauge working!(bad tank has bad sending unit too!)--I dont go too far,one tank is enough!(It would take almost 100 bucks to fill both! :blush: )...thats a keeper though,that post with all the dual tank info! :cool1:
  5. Esteban86K5
    3,712
    Bakersfield, CA
    That will hopefully help him out. I appreciate it.
    THANKS!!!
