Dual Ignition Coils? Crazy, yes but will it work?
Discussion in 'The Garage' started by LKJR, Oct 15, 2003.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Ok as college students do I spend most my time in a foggy daze. While driving in this mental haze today, the fog lifted and I had an idea. If I understand the Ignition Coil correctly it holds a massive charge let go when it fires a plug. or something to this matter. The purpose of a MSD box (other than the multi spark) is a heavier more powerful spark. So is there any reason you couldn't wire up two coils (HEI) in parallel and get twice the spark?. or would it only charge each 1/2 way?
    someone shine some more light on this idea... I"m sure someone in some back woods hole has already tried this..
  2. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    I don't have any first hand experience on how well it works, but I have seen it done many times...
  3. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Uhm, wouldn't you want to run them in series so it'd store more energy? Capacitors you put in parallel and inductors you put in series to get them to add up.
    I think if you want more gonads you're better off going with capacitive discharge.
    Basically, what happens now, is that the primary coil charges the ignition coil and then when the ignition coil is no longer being charged it releases its energy.
  4. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    There are a few things to consider about Spark,Intensity,duration.Also another factor is fuel type,compression.Flame travel
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Ok if I remember right one of these is on top of the cap and the other inside right? I'm thinking the one on top of the cap. easier to double up... parallel or series either way. I'm looking for some cheap gonads here. I was thinking parallel becuase if it was in series one would discharge into the other (mental theory, that fog again ya know) I know there's some EE's here somewhere. Come on Greg where ya at, you know a lot on this kind of stuff...
    I've got an Accell coil on there now and I have my factory coil. Would they have to match up to do this or could I do it with the 2 different kinds?
  6. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Well, I'm in my fourth year as an EE student... but this is highschool electronics. I actually learned all this back when I was a freshmen in highschool...
    If you want more magnetic energy (voltage or "electromotive force" aka emf) stored in an inductor you put more coils in. You do this by putting the inductors in series.
    Inductance (L) is added in series. Lt=L1+L2
    If you want more electric energy (current) in a capacitor you put more surface area in. You do this by putting the capacitors in parallel.
    Capacitance (C) is added in parallel. Ct=C1+C2
    If you want more resistance in a resistor you put less doping in. You do this by putting resistors in series.
    Resistance (R) is added in series. Rt=R1+R2
    If you put two inductors in parallel:
    Lt=1/((1/L1)+(1/L2))
    If you put two capacitors in series:
    Ct=1/((1/C1)+(1/C2))
    If you put two resistors in parallel:
    Rt=1/((1/R1)+(1/R2))
    I think that's the jest of it. I'm tired. I have a Materials exam I've been studying for.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I can't remember from electronics, but what we call a, "Spark" in the automotive world is nothing mroe than, "Inductive kick". The thing I can't remember is, does more inductance cause a stronger inductive kick? I remember playing with coils and switches and the quicker you flipped the switch, the stronger the kick was.
    It might be crazy, but I know damn well that more voltage = stronger kick.
  8. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    so if I wire up two of the top coils is it gonna hurt anything inside the cap? also do you think I will see any advantage to doing this?
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I doubt you'll hurt anything but I don't think you'll see any benefit.
    Either way, from what I hear, swapping to a coil other than the one in the cap will provide a drastic improvement over just using the regular factory in cap coil.
  10. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I've switched to an Accel super coil and bosch platinum plugs. lots of improvement over my autolites and factory coil.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Well I know you blubies can't post in the 73-91 forum, but do a search in there on Bosch platinums. Those plugs are total trash. I'd get that crap out of my engine ASAP if I were you.
  12. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I'll search, but they seem to work better than the autolites I had in there...
