Dual NP205's?
Discussion in 'The Garage' started by u2slow, Nov 18, 2002.
  1. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Dual NP205\'s?
    Has anyone tried to see if a NP205 output shaft will fit together with a 32-spline NP205 input? I think they're both 32-spline... I guess it depends on the pressure angle.
    Just figuring on the feasibility of a dual NP205 setup. Maybe chop off the front output section, or go to a Ford NP205... and then of course there's the married/divorced debate...
  2. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Re: Dual NP205\'s?
    I thought the 205 was a 1 section casting unlike the 203.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: Dual NP205\'s?
    I dont even know if the input and output shafts are the same diameter between the two. Almost seems that a coupling sleeve would need to be fabbed along with the adaptor, kind of like what ORD has.
  4. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Re: Dual NP205\'s?
    I know it can be done with them divorced, but I dont know about married. Later
  5. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    Re: Dual NP205\'s?
    If you farted consistently for 6 years and 9 months,enough gas is
    produced to create the energy of an atomic bomb.
    [/ QUOTE ] LOL good fact man!
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: Dual NP205\'s?
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Re: Dual NP205\'s?
    i thought about this. i can get a divorced ford 205 for a good price. so i have been thinking about it. i dont see a reason it could not be done.
    i just dotn have the time, or the for axle. but if i did i would. if you are interested in the 205 let me know.
    Grant
  8. u2slow
    May 9, 2001
    2,217
    BC Canada
    Re: Dual NP205\'s?
    Correct.
    I mean taking an NP205 and literally sawing off the portion that houses the front output /forums/images/graemlins/eek.gif and brazing on a cap. Then mating the male 32-spline rear ouput to the 32-spline female input on a NP205. I would build an adapter to "fill-in" the gap. /forums/images/graemlins/grin.gif
    I'm just wondering if anyone had inserted "Tab A" into "Slot B" - so to speak /forums/images/graemlins/smirk.gif
  9. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    Re: Dual NP205\'s?
    I just checked and this will work if you use the right combo of parts!
    **NOTE: Everything mentioned below is from various TH400 version GM 205 t-cases**
    A tailshaft from a slip yoke 205 will fit the female 32 spline input shaft so that combo works. *Now stay with me this might sound confusing* I don't have a loose short bolt on style tailshaft to try so I tried to put the bolt on yoke onto the long slip yoke shaft (checking spline compatability) and it will not go on it. This means you would have to a slip yoke tailshaft on the front case and, of couse, the rear case would need a 32 spline female input shaft. I would think you'd want to use an early shorter version input shaft in order to make the adaptor between the two as short as possible.
    VERY COOL IDEA! /forums/images/graemlins/thumb.gif
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: Dual NP205\'s?
    Even if this idea would work, you still need to do one of two options to get the necessary driveshaft clearance on the front:
    1. Use a Ford 205 after the tranny so the front output will be on the opposite side.
    2. Index the GM 205 by having a custom made adaptor made for it after the tranny. Either turn it up or down (which can/will lose ground clearance) and hope you have enough room for the rear 205 to allow the front shaft to work thru it.
    Almost sounds too complicated to get this to work. Just easier to use the 203 because of its range box.
  11. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Re: Dual NP205\'s?
    I know of a jeep that has done this mod, I will see if I can get in touch with him to see how he did it. I personaly think it isn't worth the trouble. Just use the 203/205 combo unless you just want to be diffrent.
  12. Flexy K20
    Oct 22, 2002
    398
    Bay Area, CA
    Re: Dual NP205\'s?
    Here is the guy that did it. Goto http://www.sierrarockcrawlers.com/main2.html then click on vhicles and click
    on the second jeep down. He is running a 2wd SM465 also. If he can fit all this under a jeep, then someone
    should be able to do it with a blazer. If you want more info you could probably contact this guy. Hope this helps
    Later -Flexy
  13. u2slow
    May 9, 2001
    2,217
    BC Canada
    Re: Dual NP205\'s?
    I'm not into buying high-buck parts. As good a deal as the ORD Doubler is, my Canuck-buck doesn't go far enough.
    As for home-brewing a 203/205 Doubler, the main problem I have is getting the output shaft cut down and re-splined. Sure its do-able, but its one more thing raising the cost.
    I HAVE a few 205's - a remote Dodge one (I can't get the yokes off!), a spare long-input one for my '91 crewcab. Just thinking about what I can do with what I got, and the least custom work /forums/images/graemlins/grin.gif
  14. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    Re: Dual NP205\'s?
    get a chevy 208 hack off and reweld a flange on it and then get a th400 version 205 and then make and adapter .
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: Dual NP205\'s?
    Thats easier to do with a divorced t-case since you can position the rear t-case in any way that will allow driveshaft clearance.
    The trick here is to hook up the 205's together, like the Doubler. Direct case housing to housing.
    Using the divorced, or remote, t-case allows you to turn the t-case down for more shaft clearance under the t-case in front of it, if it has the same side front output.
  16. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Re: Dual NP205\'s?
    Homemade Doubler.
    In Gordon's article he stated that Moser cut and resplined his output shaft for under $100.
  17. Chris Demartini
    2,406
    Dumont NJ 07628
    Re: Dual NP205\'s?
    <font color="blue">Lower axle gears
