dual shock fronts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jonny-K5, Jun 18, 2003.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    ok, my truck has dual front shocks, i ordered a lift kit with two shocks, now which mount is standard location? the longer, straight up and down mount, or the shorter one that angles to the rear of the truck? im guessing its the straight one.
  2. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    if ur truck (as almost all 80-up i believe) have dual front shocks, both are the stock mounts. but, i would use the straight up and down to get the most travel and articulation. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif i know ho9w ya feel too, i was wonderin the same thing when i was lookin at lifts.
  3. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    Your right! Most lift kits only come with 2 front shocks and they utilize the upper mount as the primary location.
    /forums/images/graemlins/burb.gif
  4. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    ya i thought it was the straight up and down one. i pieced the lift together so i could have gotten four shocks but i thought i would see how it handles with 2 first. im using 3in EZ rides, do ya think 2 will handle them?
  5. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    the rearward of the two is the standard position with the forward of the two being the auxilary shock. Like said above just use the taller position (auxilary mount) and run a longer single shock.
  6. Big Red
    Jan 9, 2003
    250
    Bristol, CT
    thats how i would run it too. using the taller shock will prevent u from having to use a shorter one that could bottom out easier, and limit ur articulation on the trail, not much, but big blazers need all the help flexing they can get. /forums/images/graemlins/thumb.gif
  7. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    as far as im concerned the extra shock is just for looks! its really not needed at all..but it does looks cool! /forums/images/graemlins/thumb.gif
