Dual Shock Question
Discussion in 'The Garage' started by h0nke, May 16, 2005.
  1. h0nke
    h0nke Registered Member
    May 3, 2005
    35
    Firth, ID
    Anyone installed a dual shock kit on their truck/blazer? I installed the front yesterday and want to now install the rear.
    I would appreciate if someone could post pics of the rear dual shock kit installed.
    Here is a pic of the kit I have: http://www.pcslayer.com/73-reardualshock.gif
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    look in my webshots, thers like 3 or 4 pics of em.
  3. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    may i ask why would you do that? unless your building it for the street...
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    good question...
    j
  5. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    i have been considering a dual shock at each wheel setup... how do you like it... is it a real big difference? i konw for sure i will do the rear at least for load and traction purposes.
  6. h0nke
    May 3, 2005
    35
    Firth, ID
    whats wrong with dual shocks for off-road use? its mostly a huntin truck.
    and thanks for the pics chris.
  7. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I have dual shocks up front (from factory) and I would never go to a single. I don't "wheel" alot though. I want it to drive well.
  8. h0nke
    May 3, 2005
    35
    Firth, ID
    hey chris - i thought the rear shocks where supposed to be mounted in the same direction? like when you have stock shocks one side goes toward the front the other side shock slants toward rear. so my question is: you are supposed to mount them in a V like that?
    i love the MLK day pic too man, we do the same around here.
  9. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    the V shape your referring to in the back does a few good things...
    if the come from the frame and go back to the axle, then they reduce axle hop, and you gain traction. from the back of the frame forward to the axle they help more for towing and loads... having the V helps for both.
  10. h0nke
    May 3, 2005
    35
    Firth, ID
    ok thanks - i am going to install the rear this weekend.
    the front install went ok. the only thing I am not happy with is the bolt head for the long bolt that goes through the shocks, isn't completely flush aganist the bracket. i am not sure why. oh well it should be fine im going to run it for 100mi then check and make sure everything is tight.
  11. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I had dual shocks and it rode like crap. took one set off and it rides 100% better
  12. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    No prob on the pics man, looks like all the other questions are answered you had. The bracket on the rear axle however wasnt exactly the best fitting thing in the world. Had to do a little grinding to make it work even halfway decent. I got dual shocks all around, rides pretty good, a little stiff, but I prefer a stiffer ride to a soft, floaty feel anyway.
  13. h0nke
    May 3, 2005
    35
    Firth, ID
    im scared now since people keep saying it won't ride good =(
    but 8 brand new shocks has to beat 4 old pieces of junk.
  14. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    whats the worst that can happen, you put em on, dont like em, pull 4 of em back off, and then you have 4 more to replace the ones still on the truck. So long as you dont have like 8 rancho RS5000's shouldnt be too bad.
  15. h0nke
    May 3, 2005
    35
    Firth, ID
    they are skyjacker shocks. guy gave me the shocks and kit when i bought the truck.
