Dual shock question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, Aug 13, 2001.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I am planning on removing one of my dual front shocks, but have a question as to which one to remove. I have been told to remove the front one but it seems to me that I would get the most shock travel out of the front one instead of the rear shock. Also, if I remove the back shock, how do I keep the front one on since the back one spaces the front out? Can anyone help me with this??
    Thanks 88K5Jimmy
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I removed the front one. Well, after the lift install only coming with single shocks, I opted to leave the front one out.
    Does anyone have a grinding disk I can borrow?[​IMG]3/4 in progress[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I removed the back one since it is shorter.
    Brian
    <a target="_blank" href=http://84k5.coloradok5.com>84k5.coloradok5.com</a>
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I removed the front one for 2 reasons. First off is the upper shock mount sits a little lower than the front one so my axles can droop a little more before my shock becomes a problem. and second because your front axle moves back as it compresses therefore I felt that the rear shock would have a better angle to work correctly. But again that's just my .02
    <font color=blue>Esteban</font color=blue>
    <font color=red>HAVE YOU EVER HEARD OF CHATA?
  5. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
