Dual Shocks - How to??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79Guy, Jan 15, 2001.
  1. 79Guy
    79Guy 1/2 ton status
    Jul 8, 2000
    178
    Southeastern VA
    Hello Again,
    I understand dual shocks may not help the ride: but they will help fill up some of that space under my lift!
    OK, so what does it take? I've got a '79. What kind of mounting hardware does it take, front and rear, for dual shocks. Where do I get it?
    (BTW, does ANYONE like dual shocks?)
    '79 Guy
    1 Blazer - 7 Children
    <A target="_blank" HREF=http://79guy.coloradok5.com>http://79guy.coloradok5.com</A>
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I have dual shocks on my front. They were on my 86 K5 when I bought it. So I don't now any diffrent. Mine does not have a lift though. The end of this month I am putting a 4 in lift on and staying with the dual shocks on the front. But like I said I don't now any diffrent.
    Become one with nature................Then marinate it.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I'm pretty sure all you need is the upper bracket for the inner shock. The shock uses the bracket on the axle, but with a longer bolt that goes through the bracket and another shock on the inside.
    90K5
  4. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    on the truck i sold, i had dual RS9000s on the front. the ride was great, becuase you set each one at a different rating to get different ride characteristics.
    Knife.
    knife.coloradok5.com
  5. Mr Red
    Mr Red 1/2 ton status
    263
    Washington, DC Metro Area
    regarding front: 2 choices. longer bolts in existing upper and lower brackets, with spacers etc. Or, LMC sells the front stock quad upper bracket. There are also aftermarket front mounting brackets. If you change brackets, be prepared for removing frame rivets of the old one and/or drilling frame holes for new brackets. Use grade 8 bolts. I spent an entire day trying to find new ones to replace grade 5 bolts that were worn when I replaced front upper brackets. Found them at Lowes (n/a @ HD, ace hardware, NAPA, or dealer)
    Can't speak to rear mounting.[​IMG]
    <font color=red>David, '86 K5</font color=red>
