dual shocks up front...yes, no, maybe?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82K5_6.5L, Feb 26, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    i am thinkin about putting dual shocks up front..any pros and cons i should know about?
    thanx /forums/images/graemlins/ears.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Pro - they look real cool when you're crawling curbs at the mall.
    Con - they generally ride like crap and cost twice as much to replace.
    If you do it right and get shocks that are valved for a dual shock application then it will ride OK, but it still comes down to whether you need duals or not. If you are doing desert racing or something along those lines then there is a benefit, but for the majority of situations, even with really big tires, there is no point other than for the looks of it. If you want to do it just for the looks then that's fine, just get the shocks that are valved for the applications.</font>
  3. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    sounds ok, well i dont do desert racing, i have a diesel so its slow...haha, but if it rides rough i dont think i'll get them, my neighbor has a Jimmy w/ duals and he doesnt like em'... thanx for the help
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    ...my dual shock brackets are hanging on the wall... TOO STIFF.
  5. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    After I put my winch on my dual shock setup feels pretty good, before the added weight of the winch it was too stiff.
    Put them on and you will have an excuse to buy a winch /forums/images/graemlins/thumb.gif
  6. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    I have dual shocks on my Jimmy.... The shocks are toast. Do I have to change the mounts or can I only mount 1 shock in the dual mount? and which mount should I use if possible?
  7. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yeah Id like to know the same thing, can I just take one of the shocks off each side and leave the brackets the way they are?
  8. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    i've tried 2 ways on mine..
    1sts was taking an old set and draining the fluid out of 'em (kept the look, lost the stiffness), and that worked OK for a while. BUshings got worn, so went to option 2.
    Left them (actual working ones)in the factory single shock location and trashed the 2nd.
    Much smoother/softer ride now. Think i had to change the lower bolt (shorter), but don't remember without going and looking at it. (i miss my memory!!!)
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    with modern shock technology dual shocks really arent necessary unless u r a desert racer hittin whoops at 70 mph etc. /forums/images/graemlins/smile.gif i took mine off a while back, havent missed em.
    j
  10. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    If you run a snow plow, they make a difference, if not, they just look cool and ride rough.
  11. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    has anyone tryed running duals with RS9000's I was thinking if you ran them all the way soft it probably wouldent be to bad
  12. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you do remove one, remove the inner one. It is shorter. You want the longer shock on there so you have less limitations on flex. I have also dented my inside shocks on the leaf springs so the can get in the way of things in there.
  13. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Why buy 6 shocks, when you can buy four and adjust them to where you want them anyway. I have quad shocks on my sub. but I will be going to just one on each side up front when I get my Bilstein's. You only need four if you have a plow, winch, really heavy front bumper, or a fishing cooler out front. If you don't have extra weight then all four are not neccesary. /forums/images/graemlins/burb.gif
  14. 1Blazin71
    1Blazin71 1/2 ton status
    Aug 23, 2000
    112
    Los Angeles
    I've got dual RS9000s in my 71 with pretty soft Alcans. I run em all on 2 and like it way better than the single RS9000 setup I had before. I get much less sway with them and dont find the ride harsh in the least with the soft springs.
    Until I went to duals I thought I'd have to add a sway bar to stop wetting my pants on high speed turns.
    Guess it depends on your particular setup: spring rate, weight, etc. I'm happy with duals on my junk.
  15. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I've got quad shocks. I'll be eliminating two of them when I switch axles.
    They came on "plow package" vehicles and were common on diesels for some reason even without the plow package. I don't know why.
    I kind of like mine. It's stiff but I don't have the pogo-stick front end my friend has with single Ranchos. I can also let the front of my truck fall off something and not bottom or have it try to launch into orbit on the rebound. I don't have those "oscillations" you get with tired out single shocks even though my dual shocks are tired.
    If you do decide to go quad shock make sure you get the right "auxilary" shocks. They have a different dampening rate than the main shock (which is also the single shock type). If you run two main shocks on each side then it'll be so stiff you might as well put pipe in for shocks.
    When I lift my truck and put the new axles underneath it I'm going with single shocks. It isn't really necessary to have quad shocks unless you've got 400lbs hanging out in front of your bumper.
