Dual shocks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, May 9, 2001.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    Ok. My 1988 has 4 shocks on the front axle (2 on each side). Is this standard? It sure looks like it but the K5 of a friend of mine has not. (and he is jealous, hehehehe).
    "K5 Grand GT Blazer Silverado in the Netherlands."
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    It may be standard on your blazer. Then again, lots of people put dual shocks on as a mod. Some 3/4 I think have dual shocks.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  3. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    It was an option from the factory; quad front shocks- mine has them too. If you're upgrading or replacing the shocks, I'd save some bucks & ditch the second set.
    Brian
    89KBlazer
  4. Sammy
    Dec 8, 2000
    250
    If I'd put something like Rancho 5000's in, do a dual or single. And if a single, shall I use the front or the rear one?
  5. Brian 89KBlazer
    779
    Ontario, Canada
    Can't really picture it right now (I"m at work) on which position to use (maybe someone else could jump in here) but yes, if you're going to something like an RS5000, it's made to carry the load as a single shock applicaion. I think that you can get a dual shock verions (some companies make them) but they're only a softer valved version of the same shock & your still buying the extra shocks.
    Good Luck
    Brian
    89KBlazer
  6. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    My old 87' Blazer had singles and i later used the Trail master quad setup. My 89' Sub 1/2 ton has Factory quads.
    One From None
