dual snorkel air cleaner
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85k5blzr, Mar 28, 2001.
  1. 85k5blzr
    85k5blzr 1/2 ton status
    Jan 10, 2001
    103
    Houston, Texas
    I was thinking about buying a K&N air filter. I was wondering if i would benefit even more by getting an Olds dual snorkel air cleaner and running dual snorkels to the front since there is even space for one on the driver side or would it not benefit me much at all? If so, what year olds air cleaners work best?
    85 k5 blazer with an old 305....must have more power! [​IMG]
  2. 85k5blzr
    Jan 10, 2001
    103
    Houston, Texas
    sorry, new at this stuff, but i would guess that the extra air flow through the K&N would supply a descent boost in performance?
  3. freeforever
    freeforever 1/2 ton status
    Feb 21, 2001
    305
    Missoula, MT
    The more air flow the better...you may see some inprovement in power and maby some in gas mileage...but hea that sounds like a cool Idea...that is if it's not to expensive?
    "Fool me once shame on you...fool me twice shame on me"
  4. 85k5blzr
    Jan 10, 2001
    103
    Houston, Texas
    What i have heard you can do, and saw an article somewhere about it, is you can take an Olds dual snorkel air cleaner, put it in place of the K5's and get an aditional plastic hose and run it to the other side. If you look under the hood, you can see a place where you can just knock out a little metal piece and put another splash guard in. Everything can be found at a junkyard.
  5. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I used a dual snorkle air cleaner from a late 70s Corvette. It you have ac, you might have some clearance problems. I had to add a small spacer between the air cleaner and carb so that the second snorkle would clear the ac lines.
    DJ
    78 K5
  6. 85k5blzr
    Jan 10, 2001
    103
    Houston, Texas
    Did you notice any difference when you added it?
  7. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Don't us an air filter that's exposed if you like mud and lots of water. Use the stock filters set up or get a snorkel.
  8. dyeager535
    26,975
    Camaro one out of the mid-late 80's is going to be easier to find. problem is that they are not a high "capacity" air cleaner, like some of the trucks got in the 80's. The car air cleaners were all very "short". My take on that would be that off the line, the taller air cleaner has more available right at the carb/tbi unit. There is no problem getting air through the small snorkel that way, since there is enough in the cleaner housing.
    Cut off the snorkel from another truck air cleaner (cars take a different size hose anyway) and rivet or weld it to your existing truck air cleaner. (obviously open the hole up!) Use the SAME type of hose that the passenger side uses, and punch out the "hose adapter" from the drivers side of the core support.(used on the straight sixes) Surprise surprise, the adapter that fits int eh core support is the same for both sides. Your done, can have working thermac, and uses all stock, readily available parts.
    Dorian
  9. 85k5blzr
    Jan 10, 2001
    103
    Houston, Texas
    Can you tell a difference in performance afterwards? I'm just wondering if it is worth it.
  10. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    <A target="_blank" HREF=http://www.shelby.net/mgervin/dualsnor.htm>http://www.shelby.net/mgervin/dualsnor.htm</A>
    [​IMG] Semper Maintenance!
  11. dyeager535
    26,975
    Not without going to the track or testing it on a dyno. I can sure hear the secondaries more though : )
    It's too easy to do, and a proven benefit, no matter how small, to not be worth it.
    Dorian
  12. 85k5blzr
    Jan 10, 2001
    103
    Houston, Texas
    now i just wonder if i am going to pass insepection.....haha
    thanks for all the info
  13. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    The master cylinder gets in the way of the second opening so you have to place it just right. I have the huge 5" air cleaner and I'm doing the same thing. It can be done but I've just heard of most guys cutting a section out of the cleaner and welding in the second piece. Thats what I'm doing anyways, a good fit because its custom made.
