dual timing chains
Discussion in 'The Garage' started by vortec, May 7, 2006.
  1. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    my old 350 had one timing chain, but i went with duals on the reman that i picked up, friday. will my old cover fit over them? i would check, but that cover isn't coming anywhere near my shiny (if grey can be shiny) new engine until i've thoroughly degrimed it. it got a little nasty on the old engine.
    also, i like the flat grey look, but how about a white engine, to match the truck? i don't think i've ever seen a white one.
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    A double roller chain will usually fit under the stock cover, But check your block clearance on the back side of chain. I had a 350 with a double that contacted the block and wore down the face of the block, dropping metal shavings into the pan. I found it when the Oil pressure dropped and I pulled the engine out. Not all block castings are the same, so clearance should always be checked. paint it any color you like!! I had a yellow engine in a yellow camaro, but I prefer "satin":D black!!
  3. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    i have to say, i've never actually seen the timing set contact the block. stange. something i'll be sure to check for, though.
    i think white would look dingy really fast, after the first day of mud. i really like the bare metal look it's sporting from the reman shop. but i don't want it to rust up or anything.
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    clearcoat :confused::D
  5. diesel4me
    Jul 24, 2003
    17,552
    939
    Massachussetts
    paint..
    Then you'd like "Cast-Blast" paint by Seymour...it looks just like freshly sandblasted iron..I think they make engine heat resistant version of it..we used tons of it on antique restorations..:crazy:
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The best color to paint an engine is black because it helps to draw the heat outward and help slightly with cooling.
