Dual to single wheel D60
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by deothrwhtmt, May 9, 2002.
  1. deothrwhtmt
    deothrwhtmt Registered Member
    Feb 24, 2001
    61
    Maryland
    What parts do I need to change over?
  2. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Four dually-rims and for both side an adapter / spacer. But the truck become min. 93” in the rear
  3. FSJeeper
    FSJeeper 1/2 ton status
    May 6, 2001
    265
    Texas
    You will need to get Chevy or Dodge single wheel hubs. They bolt on. Tthe bearings, spindle, rotor, etc. are the same on the dual and single wheel model.
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    the only thing you have to change is the hubs and if you plan on using the rotors the hole must be reemed out to the proper diameter to except the new studs for th SRW hubs. your best option is to have the DRW hubs machined to SRW hubs, these guys can do it for you http://www.wagonermachine.com/ they are not the cheapest at $250 for the pair but they know exactly what they are doing. in fact i put mine in the mail yesterday to have them machined. If you are looking for a bolt on replacment boyce$$ have them for $700 for the pair including rotors. but the rotors are only worth $200. so that leaves $500 they are charging for the hubs $bling$ $bling$
