dually 14 bolt
Discussion in 'The Garage' started by gforce, Nov 20, 2004.
  1. gforce
    gforce Registered Member
    Nov 25, 2002
    9
    West Columbia, TX
    Greetings
    I have a 14bolt dually rear end. Can it be converted to SWR, and fit under a k5?
    Thanks for any input,
    GFORCE
  2. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    It all depends on the rear end. You can put SRW bearing hubs on it and push the wheel mounting surface out a couple of inches per side but there are some cab & chassis housings that are really narrow. I don't know if there is anything that can be done for the really narrow version.
  3. gforce
    Nov 25, 2002
    9
    West Columbia, TX
    The rear end is under a 1 ton panel van. If it is not the real narrow version, all I need to do is change the hubs?
  4. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Well, looking back I think my answer was a little vague. Yes, changing the hubs will widen the axle's track width but you will have to do something with the brakes (the hub change will relocate the drums further out). The easiest solution would be a disc braket conversion.
    You will probably have to relocate the spring perches and shock mounts to fit your K5.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    why not just find a 3/4 ton 14FF? they're EVERYWHERE, and cheap. plus, its a direct bolt in. save yourself alot of work.
  6. gforce
    Nov 25, 2002
    9
    West Columbia, TX
    I didn't realize it would be that much work to change the dually axle over. Seemed like a good idea since I already have it. Guess the way to go would be to buy the 3/4 ton.
  7. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    3/4 ton 14 bolt FF's arent that common, the majority of 3/4 tons I've seen always have the SF. If you fill out your profile, maybe someone nearby has an axle they'll sell or maybe even trade you. If you're anywhere in Texas, I just scored a 3/4 ton 14 bolt today. /forums/images/graemlins/woot.gif
  8. gforce
    Nov 25, 2002
    9
    West Columbia, TX
    I'll fill out my profile. I'm about an 40 miles south of
    Houston, TX.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    FFs are under every SRW 3/4 and 1 ton truck built between 1973 and 1981, and in the 1 tons until 1991. it was also used after 1991 in 1 ton applications, although the housing is quite a bit different than the older units.
  10. afroman006
    Aug 21, 2002
    2,876
    OOhhhh, I didnt know that. The truck I bought today is a 82 Crewcab 3/4 ton. I know these are fairly rair, I dont see crewcab 3/4 tons very often but they always have the FF in them. Now why the hell did GM have to cheap out and create that damn SF, I swear that thing is a plague upon the earth. So, would you be interested in buying my 14 bolt? $200 I could bring it to you, you're close enough to my commute between college station and corpus christi.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    SF a plague? What's wrong with it? I ran one for three years with no issues. It's plenty strong, I'd say THE strongest stock SF ever made or damn close.
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    how does it compare to a Sterling?
  13. afroman006
    Aug 21, 2002
    2,876
    I know I had one in my burban for awhile, they're allright. I was refering to parts junkies like me buying parts trucks with them in it and not being able to give them away.
  14. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    By "Panel Van" do you mean a "P" series step van???.If its one of those it might have the same spring pad spacing as a pickup--I'd get the tape measure out and check--you might get lucky and the housing would bolt in,then all you would have to deal with is making it a single rear wheel(if thats what you want).Dually K5 anyone?? !. /forums/images/graemlins/smile.gif
  15. gforce
    Nov 25, 2002
    9
    West Columbia, TX
    $200. Is it ff or sf? What gear?
  16. gforce
    Nov 25, 2002
    9
    West Columbia, TX
    Dually K5. I've thought about it on one of my parts trucks.
  17. afroman006
    Aug 21, 2002
    2,876
    Its a FF. I dont know what gears it has in it yet. I havent picked the truck up yet lol. I suspect it to be 3.73 though, because its a 3/4 ton. Might be 4.10s however, but I'll let you know.
