dually 14bolt disk brakes
Discussion in 'Suspension | Axle' started by rooferbret, Dec 11, 2005.
  1. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    Sold!
  2. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
  3. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    some pics .
  4. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Why the bleeder screw on the bottom?
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Its probably the caliper for the other side just thrown on for a pic...
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    how's about a kit for the D70 dually? anything for that yet, or are they about the same?
    kinda new to the whole D70 setup here:o
  8. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
  9. 4xcrazy
    Oct 31, 2003
    9,472
    5
    excellent,,,thanks:waytogo: :saweet:
    edit,,,,,,SHEEEOT !!!!!!!,
    they are pretty proud of those things!!!:eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1:
  10. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    How about pics of the D70 dually set up?
    Thanks,
    Eric M.
  11. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    up from the dead, Still for sale.
  12. ZukiJohn
    ZukiJohn 1/2 ton status
    May 29, 2007
    215
    Apache jct Az
    Dually rear disks
    You still have????? I'm interested.........
  13. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    Up one more time.
  14. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    fyi that rotor looks like a newer factory disk brake rotor for gm drw axle. :whistle:
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    Whats the difference between the 14FF and D70HD kit?
  16. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    When i talked to one of the guys at blackbirds they said the mount might need to be ground a bit. I think to go around the axle tube.
  17. sweetk30
    Nov 1, 2004
    25,554
    548
    all i have read before. the dan 70hd has bigger tube than 14ff axles. 98% sure all brake parts swap around.
  18. thatK30guy
    Jan 12, 2001
    32,076
    55
    As per rooferbrets pics, looks like the Blackbirds brackets are inboard of the drum brake flange brackets.
    The TSM's show them to mount outboard of the flanges.
    Kerts, from appearing like a regular 14FF bracket, also mounts outboard the flanges.
    Wonder if the spacer between the rotor and the bearing hub is the main factor as they seem to be different thicknesses between the Blackbird and TSM kit. :thinking:
  19. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    After looking at the tsm kit I wonder how thick the spacer is on the caliper mount.
    If it puts the caliper behind like the blackbirds kit.
    The rotors look the same between the two kits to me. This is the caliper mount and why it needs to be ground to fit the dana 70 P1030023.JPG
  20. thatK30guy
    Jan 12, 2001
    32,076
    55
