Dually axle questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mpascino, Aug 4, 2001.
  1. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    I am aquireing a matched set of axles from a dually tommorrow. Can I use the rear on my blazer without any problems? I know these rears are narrower, will there be any clearance problems? If so I might just have to regear my 14 bolt. Second question, what can I do to the front end to remove the spacer to obtain the proper offset for the wheels? Is this a task that just requires removing a piece or is it something that needs different parts? Also , are the spring mounts in the proper location? Thanks in advance for all the help.
    Mike
    You call that dirty!?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No, will require spring pad changes.
    Tim
  3. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    You will have to get new single wheel hubs for the front axle. You can re-use the rotors. Don't know about the rear.
