Dually conversion from single
Discussion in 'The Garage' started by kgblazerfive, Dec 29, 2004.
  1. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    srw to drw
    how hard is it to change the rear and what parts do I need
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Depends on what type of truck. I see in your sig that you have a crew cab 4x4 and I am going to figure it's a 1 ton. If it was me I would either find a dually bed in a yard or come up with the fenders and have a body shop connect them on to the existing bed along with a new paint job to the whole truck so it will look factory and not like a crayon box. I would get a dually rear end and swap it in because I think the rearend width is what is different between an SRW and DRW, not just the hubs. For the front I would trade somone here at CK5 my SRW front hubs for the dually versions (i'm sure there would be plenty of folks that would love that trade) and finish it off with some nice 16" polished alcoa rims. ;)
  3. kgblazerfive
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    The 82 one SRW 4x4 that I own is for sale and I might have it sold and I have found a 2x4 big blk. one ton srw that is more of what I need, tow vehicle, but I was thinking about converting it to dually so that is why i was wondering
  4. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    swap info
    some 1 ton rears came with the small brakes on them most were big 13" dia thes wont work . wont clear the bell of the dully rim. if you have the smaller you might just need to change studs for longer but not 100% sure on the axle flange widths. dont forget the dully lug nut plates that gm runs for the rims. with the front like info from above, swap just the rotor hub assbly, rotors are diff in mounting hole dia. , need sfw rotors for srw need drw rotors for drw, if 2x4 front swap the hub rotor combo just the same. all brake barts are the same srw to drw. just face that wheel sits on is spaced out more.
  5. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    I'll trade you my dually front hubs/rotors for your SRW ones.
  6. kgblazerfive
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    So looks like I'm looking for a dual rear end
  7. mosesburb
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    That is the preferred method of doing this. If you keep your ear to the ground long enough, you can usually get one for well under $200.00, sometimes even for free. For some reason, it seems that these are worth nothing unless you need one right away, then you'd think they are gold plated.
    D70HD is what you are looking for
  8. kgblazerfive
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    If the sale falls through you might have a deal because I will end up keeping the 4x4
  9. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Hey, I'll try and give you a call later on. Figures, I just traded off a Dually bed that I had off an '83.
    I had a '77 with a regular single wheel 14-bolt rear that someone stuck dually rims and tires on. They ended up grinding off half the fins on the drums to make the rims clear, and it was a tight fit even with 16.5's. Not the best way to do it.
    I have access to a complete Dana 70 HD Dually rear end with 3.73 gears and 4 16" rims.
  10. kgblazerfive
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    Hey trades are excepted
  11. mosesburb
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    Just let me know. They aren't going anywhere soon.
