dually Dana 60 front
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by titanic, Apr 27, 2000.
  1. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I've been looking for a dana 60 front axle to swap in for my IFS stock front end. I 've located one out of a ford dually,(I know, I know nasty 4 letter word),and was wondering what the costs might run to convert to single rear wheel hubs and etc. Any idea?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I am not totally positive, but I think the ford front driveshaft is on the wrong side. dually rear axels are wider, hub adapters are needed to convert.
  3. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    the Ford transfercase outputs on the left side, while Chevy's are output on the right side, you'll have to have one helova driveline built to make that work, or put in a 2 wheel drive transmission and a ford divorced 205, now that would be one unstoppable / bulletproof setup especially if you had the slip yoke eliminator kit on the back of the th350.
    '77 K5
    <font color=red>mudfanatic</font color=red>[​IMG]
  4. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    The GM IFS trucks have the t-case output on the drivers side so a Ford axle is required. I've heard the dually conversion is expensive but for what they're charging for a Ford Dana 60 it may be worth it. The last Ford D60 axle I seen was going for $1400!
    Shawn
    <font color=blue>87 K5</font color=blue>
    <font color=red>454, 6", D60, 14 blt, 465, 205</font color=red>
    www.off-road.com
  5. mudfanatic
    Feb 18, 2000
    614
    Aloha, Oregon
    In that case go for it I forgot that the IFS had the output on the left side. A dually Blazer would be a site to see, go to a wrecking yard and get the dually bolt on fenders... that'd be waaay cool
    '77 K5
