Dually Dana70HD
Discussion in 'The Garage' started by chiefheaphy, Apr 23, 2007.
  1. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    To run single wheels and a disc brake kit on my dana 70HD will I need to get single wheel hubs?
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    no u don't have to, but if u did the srw hubs would make it about 3-4" wider.
  3. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    That is correct. Swapping to SRW hubs on the D70HD will only serve to widen the axle even more. The popular swap is to use hubs off a Corp 14Bolt. It will bring the WMS out to within an inch of the WMS on a DRW D60F.
  4. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    I happen to have a rear dana 60 sittin around with hubs and rotors. Any idea if they will work? on a D70HD. Only reason i'm asking is because I dont have the 70 yet.
  5. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    prolly not. depends on what it is from
  6. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    damn
    D70HD out of Chevy T-Tag box truck. I think it has a 4" tube??????
    D60 REar out of 79 F-250. I suppose that means it wont work?
    Saw some 14 bolt hubs on e-bay for like $30. I'll probly have to go that route.
    Reason for the wide axle is the huge lift. Wider track width will lower my center of gravity. DRW D60 Front/D70HD 14 bolt hubbed REar should do the trick?
    Thanks for the help.
    BRian
