Dually rear axle
Discussion in 'The Garage' started by Mudbug1979, Jun 18, 2003.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    I will be getting a dually rear axle out of an 78 1 ton truck. Was considering if it would be worth swapping over into my 79 K5 or not? If I choose not to use it, what would be worth? Thanks. /forums/images/graemlins/thumb.gif
  2. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    It'll be narrower than the front axle and you'll have to have the spring perches moved to fit it in your K5 or get the 1 ton spring hangers as well. It's probably more hassle than it's worth considering the price of a 14 bolt FF.
  3. Mudbug1979
    Aug 4, 2002
    439
    78? Would that be Dana 70 or a 14 Bolt? Time and labor is not a prob, but if I don't use it is it worth selling?
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    If it is from a Dually pickup (pickup bed with fiberglass fenders from factory) and not a cab/chassis (no bed from factory) you should have a Dana 70 that is wider than your front axle. It would not work unless you want to run stock HMMV rims with a 7" backspacing and a dually front Dana 60.
    If the axle is from a cab/chassis it will be a Corp 14 FF that is too narrow for your truck. Better to sell that one to a Jeep guy wanting 1 ton axles.
  5. nvrenuf
    Jan 7, 2002
    13,082
    250
    Mobile, Al.
    It will depend on the the truck as to which axle it is (D70HD or 14 bolt). If it is a pick up (originally sold with a bed) it will have a D70HD, if the truck was a cab & chassis it will most likely have a 14 bolt.
    The 14 bolt would probably be very narrow but a D70HD will be VERY wide (roughly 11" wider than a SRW axle).
  6. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    AHHH!!! Were there ever any 14 bolts put into dually pickups (with beds and fenders?). Or would the narrow cab and chassis 14 bolt work for my burban? I already have the 1 ton spring hangers so I know what I need to do I just cant figure out which axle I need. Thx
  7. Mudbug1979
    Aug 4, 2002
    439
    Well it looks like I will have Dana 70 To sell. My luck.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    92-up DRW pickups use the 14FF. Are you going for the narrow or wide track width? If you're going wide, just get that 92-up version and change the perches to fit your truck.
    Using the 1-ton frame hangers will mess you up for shock mounts. The passenger side will need to go right where your fuel tank is.
