Dually Shackle Flip
Discussion in 'OffRoad Design' started by 88burb, Feb 26, 2005.
  1. 88burb
    88burb Registered Member
    Nov 15, 2004
    33
    Will Your 1 Ton Shackle Flip Work On A 89 Crew Cab Dually I Will Be Towing Quite A Bit And I Was Wondering If It Still Would Be Safe To Tow Things After The Shackle Flip. Thanks Lance
  2. 88burb
    Nov 15, 2004
    33
    Oh Ya Its A 89 Gmc Dually Forgot To Put That In ........
  3. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    Burblover this topic has been beaten to death.
    88burb if you do a search here you will find many many heated discusions about towing with shackle flips.
    I have one on a 95 Ford truck and used it for all of my towing needs. I have towed upto 10,000# with the truck and never felt that it was unsafe or dangerous. I think it changed more when I put the 4" lift on with the blocks and add a lift spring. I then changed to shorter blocks with taller springs and then went to the shackle flip. It was always the same after I lifted it. I see no problems with it
    Others do
    You can also call Stephen and talk to him about this.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    As my bro stated, there's a lot of info here on this already for you to sift through, in your case, you have a solid tow platform to begin with so you should not have any problems. As you will probably read, most problems with "towing with a shackle flip" are more related to tires, shocks, springs, wheelbase, trailer type, etc. than to the specific shackle configuration.
