dually tire question
Discussion in 'The Garage' started by sweetk30, Oct 30, 2005.
  1. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    i have the idea of putting the 34x9.50x16 tsl tires on my new play toy. 1 ton 4x4 dually truck. will thay fit or do i need to space them apart some. and is there another size i can run with out to much modifying.
    thanks guys . looking for real experence so i dont buy the wrong tires. :bow:
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    I've seen this combo done many times before without any modifications to the rims, etc.
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Sometimes you need a 1/8" spacer so the tires don't touch. They are cheap and the studs are long enough that it isn't a problem
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    A guy in town has them on a 88-98 Chevy dually and they fit ok. They are very close to rubbing at the bottom where the tires bulges are. I would imagine with any extra weight or a trailer that the tires would rub each other on the bottoms. It looks awesome when he drives in just a little bit of mud and the gap between the duals is packed full... it makes the tire look about a couple feet wide.
  5. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    I have a set of 255/85/16 A/T tires on my dually. They are 33" in diameter. They will fit a 6" or 7" wide rim. The truck has 1/8" spacers between the back rims, and a 1" body lift, just to make sure everything clears. I think Dick Cepeck makes a 35" TSL type of tire for duallys as well, which will fit narrow rims on a dually.
  6. sweetk30
    Nov 1, 2004
    25,547
    542
    thanks sofar guys. if you have any pics of the tires on the truck it would be great. and i am open to other sizes as well.
    ? on 11.00r 16 mill tires . thay to wide or not?
  7. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    Here is the other tire I was talking about. It is an Interco Super Swamper TSL. The tire size is 9/34-16LT. It is 33.8" in diameter and about 9" wide. It will fit on a narrow dually rim.
  8. sweetk30
    Nov 1, 2004
    25,547
    542
    yaa thats what i was going to run. :crazy: but if anyone has some bigger tires to run with minimul work to fit this would be great.
  9. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    I think that is the biggest tire you can run without major rim modofications.
