dually vs. single 14 ff....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tipoil, Aug 6, 2002.
  1. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    does any body know the difference between a dualy rear end and a single wheel diff?
    does a 14ff from a p30 dualy would work(length ,spring pad,etc)
    Around here they are getting reel hard to get . Just have to forget the junk yard because they want to rob u (they ask 600-850$ cdn each.But they are stuck whit the p30 ones.
    Dont even think of going to d60 up front (would have to get a third job!!!!!)
    so any guess???
  2. tipoil
    Jul 30, 2002
    222
    canada guebec
    ANYONE?????
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    The dually 14b is quite a bit narrower than the single wheel version. /forums/images/icons/cool.gif Also the spring pads are in the wrong spot for a K5. Try to find one from a 3/4 ton. I got mine from a '77 3/4 ton. The only thing I had to change was the shock mounts. They hung too low.
  4. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I am running a D70 HD out of a Cab and Chassis Ford...I had to move the spring perches and make shock mounts. It I about 2" narrower on each side than my D60 front. I am running 2 1/2" spacers on the rear, so my track width is about 1/2" wider in the rear. I am builing another rearend with lower gears etc and am willling to sell the spacers. If you can get the dually rearend considerably cheaper than the single wheel, go for it. Another option is a D60 rear out of a 3/4 ton Ford.
  5. tipoil
    Jul 30, 2002
    222
    canada guebec
    FORD...NEVER tought of that..!!!
    A freind of mine said that the p30 ones was longer (maby 1 inch or so)than myne,was he blowing hot air..or not??
    The axle i'm talking about is from a foward control body(p30) purolator truck type(cargo)
  6. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    dont know that truck, but 1 ton truck duallies
    the rear axle is narrower than the single, and a dana from any of
    those will work with some minor mods
