Dually's and big tires ??
Discussion in 'The Garage' started by nvrenuf, Sep 5, 2002.
  1. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Dually\'s and big tires ??
    How big of a radial tire can you run on the stock wheels without the rear tires rubbing each other? I see a lot of tires offered that are roughly 12.50 in width, will these rub? I know spacers are available but I'm curious about tires without spacers.
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Re: Dually\'s and big tires ??
    Why not just put the single rims on it and run those really wide Mickey Thompsons /forums/images/icons/grin.gif
  3. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    If I buy the truck I'm looking at, it will strickly be a daily driver/pull truck for my trail truck but I would like to spice it up a little. I'm thinking about a 4" lift and 6 x 33's, just enough to give it a nice look but still a functional tow truck.
  4. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    theres a newer dodge dually that rolls around my area on 35 mud terrains all the way around...dont know for sure but it doesnt look like hes running spacers but those rear tires look really close to each other...
    i think it can be done...plus it looks badass when a trail truck is getting pulled by a dually thats jacked up too
    Later
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Pretty sure you have to use spacers or different wheels on most duallies to get anything wider than a 235 on there.
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    4x4Nut builds dually trucks alot, has a shop called Kats Kustoms
    he has had rims custom made, I tried to help him search for sources one time
    he will probably know the answer to this as he has done at least 2 on 44s
    with 33s you can usually find a narrow set for the rear and run some fattys up front
    you really do not want the tires to ever run against each other
